Hi
I created mpg file using Dazzle Video creator from Canon camcorder. I used TMPGENC12f for SVCD Encoding. After that I burn on Memorex CD-RW. I used DVD player Panasonic A-120 for play. The picture is coming in slow motion. Can any body give me suggesion to rectify the problem. Thanks in advance.
-Chakradhar Yadav
_________________
Chakradhar Yadav
<font size=-1>[ This Message was edited by: chakradhar on 2001-07-17 08:42:32 ]</font>
I have a Panasonic AU-120...this apparently is different from the A-120, but I cannot figure out how it is different. I've tried VCDs burned in many formats that will run great on my computer with WinDVD and other DVD player programs...but the AU-120 won't recognize anything. I'm using Sony CD-RW, Verbatim CD-RW, Memorex CD-RW...with no results at all.
Anyone know why the AU-120 doesn't work and the A-120 apparently does?
Be sure to check your model number. You may have this model instead. -
http://www.vcdhelp.com/dvdplayers.php?DVDnameid=218&Search=Search&list=0
check that for more info. -
Hi
A120 plays VCD(Memorex CD-RW). There is no problem in playing VCD. But the picture is coming in slow motion when playing a SVCD(Memorex CD-RW). Is there any problem in SVCD format while burning Nero5.5.2.4?
-Chakradhar
<font size=-1>[ This Message was edited by: chakradhar on 2001-07-19 13:25:59 ]</font> -
Hi Joe
My DVD player is A120, not AU120.
-Chakradhr
<font size=-1>[ This Message was edited by: chakradhar on 2001-07-28 15:13:18 ]</font> -
Make sure settings in Tmpgenc replicate settings for capture of the input file. Can you please specify what seetings were used for capture and encoding?
Hi jdatec
I used the Default settings for the Encoding. The options are: Interlace, Bottom field first(field B), Sourcs aspect Ratio 4:3 525 line(NTSC), VIdeo arrange method: Fullscreen(Keep aspect ratio).
The capturing is with NTSC, High qualtity. There is no probelm in capturing. That MPG file is playing in the Real player.
Can you please help me to set correct options.
-Chakradhar
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Created DVD(UDF) in Nero, works on some computers, not all
By ir0n_ma1den in forum Authoring (DVD)Replies: 1Last Post: 15th Jun 2009, 22:51 -
File created with sub2divx will not play on vlc or windows media player
By brattychiq in forum SubtitleReplies: 0Last Post: 23rd Jan 2009, 10:32 -
How to Play AutoGK Created Subtitles
By 888888 in forum LinuxReplies: 3Last Post: 6th Feb 2008, 18:19 -
Why wont windows media player play any audio from my created dvds
By thnkbg in forum Authoring (DVD)Replies: 1Last Post: 17th Aug 2007, 11:30 -
Can chapters created in Nero 6 show up in menu?
By wayney in forum Authoring (DVD)Replies: 2Last Post: 15th Jun 2007, 12:46
