Hello???
Check this one out. I captured another show from my DVR and dragged it over to HDTV2DVD. The time showed over 10 hours and the graph for the size was maxed out. Actual file size was right in line with the others at just under 7 gig and it was only 58 minutes long.
I figured something went wrong on the capture, so I did it again. Now the time showed -23 hours. That's right negative 23. I figured what the hell, and tried to process it. It is running right now and is at 12,700% complete. I have to leave, but I am not going to shut it off. I want to see what it comes up with.
Results 241 to 270 of 271
I got that one burned to a disk.
Back to tone of the initial ones that gave the errors. I ran one through mpeg2repair and HDTV2DVD will accept it now. Problem is, the time shows 1:52 for a 1 hour show. We'll see how this one goes. -
Anybody there?
HDTV2DVD program is broken. I repaired the install but the problem is still there.
It will no longer process files successfully. Including files that where able to be processed previously.
An unhandled exception has occurred.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Runtime.InteropServices.COMException (0x80040265): Exception from HRESULT: 0x80040265.
at QuartzTypeLib.FilgraphManagerClass.RenderFile(Stri ng strFilename)
at x14ee85f5d732c07f.x79ed6fa5f8db6479.x535825f93c028 407(String xa39af5a82860a9a3)
at x14ee85f5d732c07f.xb6dca8349e33d934.x8ab0d03b11b82 1b8(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at DevComponents.DotNetBar.SideBar.x83ee7ecd3d7c068f( BaseItem x6f91d5b9c12931eb)
at DevComponents.DotNetBar.BaseItem.RaiseClick()
at DevComponents.DotNetBar.BaseItem.InternalMouseUp(M ouseEventArgs objArg)
at DevComponents.DotNetBar.PopupItem.InternalMouseUp( MouseEventArgs objArg)
at DevComponents.DotNetBar.ButtonItem.InternalMouseUp (MouseEventArgs objArg)
at DevComponents.DotNetBar.SideBarPanelItem.InternalM ouseUp(MouseEventArgs objArg)
at DevComponents.DotNetBar.SideBar.OnMouseUp(MouseEve ntArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at DevComponents.DotNetBar.SideBar.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
HDTV2DVD
Assembly Version: 0.41.2250.24600
Win32 Version: 0.41.2250.24600
CodeBase: file:///C:/Program%20Files/BadgerIT/HDTV2DVD/HDTV2DVD.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
Assembly Version: 5.6.0.0
Win32 Version: 5.6.0.0
CodeBase: file:///C:/Program%20Files/BadgerIT/HDTV2DVD/DevComponents.DotNetBar.DLL
System.Design
CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
Accessibility
CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
S2DProgressBar
Assembly Version: 1.0.2109.17800
Win32 Version: 1.0.2109.17800
CodeBase: file:///C:/Program%20Files/BadgerIT/HDTV2DVD/S2DProgressBar.DLL
Interop.QuartzTypeLib
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/BadgerIT/HDTV2DVD/Interop.QuartzTypeLib.DLL
Interop.DexterLib
CodeBase: file:///C:/Program%20Files/BadgerIT/HDTV2DVD/Interop.DexterLib.DLL
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
for some reason the autofit option does not work for me.
I am using the Dual layer check and hitting autofit and I get a 1.5gig dvd with a horrible picture.
When I do not use autofit I get a 9.5 gig dvd and for some reason dvdshrink fails to open one of the vob files...
I am stuck either way... and suggestions?? -
Can you post your log file?
Below is the log... it made a 1.15 GB dvd... I had DL checked and hit autofit.
I, also, noticed that after I hit autofit the number under the meter changes from
52428800 to 50 MB... seems small
am I doing something wrong?
also, another note... this was a 3 hour nonHD show capture from a motorola box.
************************* ProjectMetaData **************************
<HDTV2DVD DateTime="7/29/2007 1:03:01 PM"><AssetSet><Asset ID="d4dbc253-4d08-4bec-9280-e946684fb4b9" Path="E:\My Captures" Filename="Great Am Bash 90 WWE247.ts" /></AssetSet><Settings><General InitialAssetFolder="" InitialDVDFolder="" InitialProjectFolder="" DeleteS2DFiles="False" UseDVDShrink="False" /><Menu AudioEncoding="Silence_mpa" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="PAL" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" /><Process AudioEncoding="mpa" Chapters="Every 10 mins" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" /><Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" /><Burning BurningMethod="NONE" DVDDrive="" NeroWriteSpeed="" Eject="True" HighDVDCompat="True" VerifyDVD="False" DVDDecrypterPath="" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" /></Settings></HDTV2DVD>
Processing assets for DVD creation
=================== AV Details ===================
file=E:\My Captures\Great Am Bash 90 WWE247.ts
FormatName=mpegts
Num_Frames=-2147483648
DurationInSecs=-2147483648
Duration=-577014:-32:-22.-7
VideoCodec=mpeg2video
Width=352
Height=480
Standard=NTSC
BitRate=0
AudioStreamCount=1
Audio1SampleRate=48000
Audio1Codec=ac3
Audio1BitRate=192
Audio2SampleRate=-1
Audio2Codec=NULL
Audio2BitRate=-1
HDTV2DVDMPG: 0kbs
Leaving source audio alone.
Using high bitrate matrices
Pass 1/1: Processing Great Am Bash 90 WWE247.ts
13:03:01: ffmpeg version CVS, build 3276800, Copyright (c) 2000-2004 Fabrice Bellard
13:03:01: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-vhook
13:03:01: built on Sep 23 2005 15:20:26, gcc: 3.2.3 (mingw special 20030504-1)
13:03:01: Input #0, mpegts, from 'E:\My Captures\Great Am Bash 90 WWE247.ts':
13:03:01: Duration: N/A, start: 14.638022, bitrate: N/A
13:03:01: Stream #0.0[0x31], 29.97 fps: Video: mpeg2video, yuv420p, 352x480, 3180 kb/s
13:03:01: Stream #0.1[0x34](eng): Audio: ac3, 48000 Hz, stereo, 192 kb/s
13:03:01: Output #0, dvd, to 'E:\My Captures\Great Am Bash 90 WWE247_S2D.mpg':
13:03:01: Stream #0.0, -1.#J fps: Video: mpeg2video (hq), yuv420p, 352x480, q=1-31
13:03:01: Stream #0.1: Audio: ac3, 48000 Hz, stereo, 192 kb/s
13:03:01: Stream mapping:
13:03:01: Stream #0.0 -> #0.0
13:03:01: Stream #0.1 -> #0.1
13:03:01: Warning, QMAT_SHIFT is larger then 21, overflows possible
13:56:35: video:916098kB audio:230217kB global headers:0kB muxing overhead 5.979276%
13:56:35: HDTV2DVDMPG: done.
13:56:35: Done: Processing assets for DVD creation
Authoring DVD Folders
13:56:35: Creating TitleSet # 1
13:56:35: SVCD2DVD: DVDfolders
Generating DVD folders please wait....
13:56:35: -->: DVDFolders creating VTS
13:56:35: -->: VTS 01
13:56:35:
DVD Folders: Processing E:\My Captures\Great Am Bash 90 WWE247_S2D.mpg...
13:57:14:
13:57:59:
13:57:59: Finalising DVD...
13:57:59: SVCD2DVD: DVDfolders
13:57:59: -->: DVDFolders creating table of contents
13:57:59: scanning E:\My Captures\HDTV2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO
13:58:00: Finalising DVD...Done
13:58:00: Done: Authoring DVD Folders -
I pretty sure it's here- note the numbers following 'Duration' in your log.
Your log:
From a working log:=================== AV Details ===================
FormatName=mpegts
VideoReDo should fix it right up.=================== AV Details ===================
file=C:\Documents and Settings\OG\My Documents\My Videos\temp\movie.ts
FormatName=mpegts
Num_Frames=215668
DurationInSecs=7196
Duration=01:59:56.1Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
ChrissyBoy
I have a TS file and trying to use HDTV2DVD. The stream is NOT highdef but the resolution shown in hdtv2dvd is very low, I ran ffmpeg in the command line ang see this, why is the res so low?? :
C:\Program Files\BadgerIT\HDTV2DVD>ffmpeg.exe -i "C:\Documents and Settings\VA00
1PU\Desktop\MOVIES\Disturbia.ts"
ug --enable-vhook
Input #0, mpegts, from 'C:\Documents and Settings\VA001PU\Desktop\MOVIES\Disturb
ia.ts':
Duration: 01:39:40.4, start: 34494.805244, bitrate: 1706 kb/s
Stream #0.0[0x0]: Data: mpeg2ts, 4778 kb/s
Stream #0.1[0x1922], 29.97 fps: Video: mpeg2video, yuv420p, 544x480, 15000 kb/
s
Stream #0.2[0x1923]: Audio: mp2, 48000 Hz, stereo, 160 kb/s
Must supply at least one output file -
Thats probably what it is.... what does gspot report?why is the res so low??SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
This, I was able to get help from the mods at this thread, just look at Gspot anf ffmpeg results, the original movie is not highdef but don't understand why Gspot shows the low bitrate and resulution:
https://forum.videohelp.com/topic337759.html#1758171 -
I think you are abosultely correct, that's what the resolution is, because the broadcast is SD (not highdef) it is 480i.
I was just really confused/concerned because your program displayed a lower bitrate, same as Gspot.....
My final issue is that the audio is out of sync, there's a delay... -
Ok, I found where the problem is but don't know how to fix it.
I downloaded VideoRedo, here are the results:
1. the original .TS file has NO audio sync issues
2. the sync issue is ONLY happening with the first .VOB file created by HDTV2DVD (VTS_01_1.VOB), the other 4 files have no issues.
I tried to fix the first file with videoredo and saved new file as .VOB, however the audio is still out of sync.
So the issue is the first file created by HDTV2DVD.
What can I do ? -
Or run the original ts through VRD (and its quick streamfix) before SVCD2DVD/HDTV2DVD
Chris, thanks but the original .TS does not have the problem. I opened this TS file with VRD and it plays perfect, so the audio issue was caused by hdtv2dvd but only for the first frame/file.
I am playing with VRD to import the original .TS file and start the whole process again but VRD only gives me an output for the first 10 minutes of the stream.....I played this resulting VOB file and it works but I don't know how to get the complete movie into a VIDEO_TS folder like HDTV2DVD does......there's gotta be something I'm missing.
Thanks for your time and help...!!! -
It is not about playing the file in VRD... the advice is to use QuickStream Fix.
I understand, but even if the .TS file plays fine?
Anyways, I tried that option but this only gives me a 1kb file when I choose either a .TS or .MPEG output. The process finish in just a couple seconds. -
Couple of questions:
I have several HD shows that I want to put on DVD.
From what I've read I can use VideoReDo or HDTVtoMPEG2 and save to .ts to remove commercials.
What do I use to put several shows on 1 DVD-DL?
HDTV2DVD + (what other authoring program?)
Will SVCD2DVD (current registration is £1 (approx $2 USD)) author several shows to DVD? -
Dwight
- Herm Albright
Thanks, as I was posting that, I was registering at the discount price.
Hoping someone can help, having an issue. I just installed HDTV2DVD but can't even get it to open.
The error message I'm getting is:
Application has generated an exception that could not be handled
Process id=0xd1c (3356), Thread id=0x5c4 (1476).
Click OK to terminate the application
Click CANCEL to debug the application
Any help anyone can offer would be greatly appreciated.
Thanks,Andrew -
Do you have .Net installed?
Is a particular MS net needed?
I just tried HDTV2DVD and like it a lot (it worked where others have failed), but it asked to install Net Framework 1.1 (which I did). Although everything works, now I have a new password-protected, hidden user account (ASP.NET Machine A...) and have to actively log into my Windows account (never needed to before nor do I want to). Can I delete the ASP.NET account and/or switch to a newer Net Framework (viz., 2.0)?
Great program! -
I'm pretty sure all the .Net's are independent, 1.1 is the one required and another won't do. As for the rest of your queries, I'd look for the answers in another forum or section. Adding 1.1 didn't cause me the problems you describe.
FYI - SVCD2DVD has all the functionality of HDTV2DVD and more, plus it's more up to date.Dwight
- Herm Albright
Did some more digging - the ASP.NET account is created by the original Net Framwork 1.1 install (which is what the HDTV2DVD installer points to), but the auto-logon issue can be resolved by a registry addition or installing the Net Framework 1.1 sp1 update:
http://www.mvps.org/marksxp/WindowsXP/aspdot.php
This doesn't answer whether Net Framework 2 would also work, but it does facilitate things! -
you can just delete the asp.net user....
as HDTV2DVD was written some time ago - you need 1.1 rather than 2.0SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
HDTV2DVD 0.4 Vista
By CathyT in forum Authoring (DVD)Replies: 2Last Post: 28th Dec 2009, 13:01 -
HDTV2DVD does not load up TS-file
By feilofix in forum Authoring (DVD)Replies: 2Last Post: 12th Nov 2008, 14:25 -
HDTV2DVD - .TS wont load
By NotSoEasy in forum SVCD2DVD & VOB2MPGReplies: 11Last Post: 15th Mar 2008, 20:09 -
How to load .ts file into HDTV2DVD?
By JR.S in forum Newbie / General discussionsReplies: 2Last Post: 15th Nov 2007, 02:59 -
Audio is out of sync after using HDTV2DVD, how can I fix this?
By geek2330 in forum Newbie / General discussionsReplies: 20Last Post: 4th Oct 2007, 17:31
