Results 91 to 120 of 271
Well, after about an hour trying to figure out dos commands, I ended up with an I/O error "usually that means that input file is truncated and/or corrupted"
Is there such a thing as a windows. or gui program to get the details on a video file? -
Ok. Try this build. It will show the details of the file if it is not compatable.
Thanks, that is a little easier....No joy yet though. I renamed the mpeg to .ts, and got this:
Version: HDTV2DVD 0.41
Build: 0.41.2250.24600
Unknown file type. Expected a mpeg-2 transport stream with a file extension of .ts or .tp
Details: file=F:\avermediafiles\test.ts
FormatName=mpeg
Num_Frames=1755
DurationInSecs=58
Duration=00:00:58.5
VideoCodec=mpeg2video
Width=1920
Height=1080
Standard=NTSC
BitRate=11132
AudioStreamCount=0
Audio1SampleRate=-1
Audio1Codec=NULL
Audio1BitRate=-1
Audio2SampleRate=-1
Audio2Codec=NULL
Audio2BitRate=-1
I renamed it to .tp and got this, same thing I guess:
Details: file=F:\avermediafiles\test.tp
FormatName=mpeg
Num_Frames=1755
DurationInSecs=58
Duration=00:00:58.5
Width=1920
Height=1080
Standard=NTSC
BitRate=11132
AudioStreamCount=0
Audio1SampleRate=-1
Audio1Codec=NULL
Audio1BitRate=-1
Audio2SampleRate=-1
Audio2Codec=NULL
Audio2BitRate=-1
The audio seems to be the problem I'm guessing. The files created by this card play just fine with Media Player 10 though...I'm wondering why I bought an HDTV card that I can't use to burn to dvd, or why they would make one. -
Well it looks like it is a program stream not a transport stream (thats why it won't load up).... But that aside i wonder what the audio is. can you email me a sample cap? Also, do you have any pointers to the audio type from the support website for that card?
I emailed you a 7mb sample. Let me know if it didn't work out. Is there a difference in the ota broadcasts? The card is only an HD tuner, but is it possible that some digital broadcasts are HD and some are not, and the mpeg file produced would vary with that?
Ok, finally had a chance to do this..Originally Posted by ChrissyBoy
By the way, thank you very much for the help.. The only odd thing I notice is the "N/A" under duration & bitrate. Everything else looks pretty close to what you posted as a go by..C:\Program Files\BadgerIT\HDTV2DVD>ffmpeg.exe -i e:\ctob.ts
ffmpeg version CVS, build 3276800, Copyright (c) 2000-2004 Fabrice Bellard
configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-deb
ug --enable-vhook
built on Sep 23 2005 15:20:26, gcc: 3.2.3 (mingw special 20030504-1)
Input #0, mpegts, from 'e:\ctob.ts':
Duration: N/A, start: 9.510922, bitrate: N/A
Stream #0.0[0x201], 29.97 fps: Video: mpeg2video, yuv420p, 720x480, 7500 kb/s
Must supply at least one output file -
thinger62: The sample is a program stream so it won't work with the program. Is there any settings on the capture card/software to save as a transport stream. Also any further details about the audio?
EndBoards: can you try this build too: https://forum.videohelp.com/viewtopic.php?p=1472459#1472459 to see if that makes any difference?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
If you want to see what's in a transport stream, you should be able to use tsreader lite. But I'm guessing maybe you're not capturing digital. Are you sure you are on a digital station? You shouldn't get an mpg except if you are doing an analog to digital capture.Originally Posted by thinger62
--Dale-- -
Well, the a180 is an HDTV card. It only tunes in my digital stations. I did a capture of two broadcasts, one SD and one HD, and can see the difference in file sizes. Both are mpg though, and there is no adjustment possible with this card:
Complete name : F:\avermediafiles\mpython.mpg
File size : 3.33 GiB
Format : MPEG-2 multiplexer
Overal BitRate : 3671 Kbps
PlayTime : 2h 9mn
Video #0
Codec : MPEG-2 Video
Bit rate : 3621 Kbps
Bit rate mode : VBR
Width : 720
Height : 480
Aspect ratio : 4/3
Frame rate : 29.97 fps
(Pixel*Frame) : 0.350
Delay : 925
and the other HD cap:
Complete name : F:\avermediafiles\20061901190331.mpg
File size : 32.0 MiB
Overal BitRate : 12334 Kbps
PlayTime : 21s 750ms
Video #0
Bit rate : 12284 Kbps
Bit rate mode : VBR
Width : 1280
Height : 720
Aspect ratio : 16/9
Frame rate : 59.94 fps
(Pixel*Frame) : 0.222
Delay : 816
I sure wish I knew how to get this on dvd...I suspect it ain't gonna happen though. This is what the manufacturer's tech support has told me:
Unfortunately, the audio codec that is used by the program can only be recognized by the AVerTV software and Media Player Classic. There is no way of changing the audio codec.
I have an email in requesting more information. -
Here's my output..
Details: file=E:\ctob.ts
FormatName=mpegts
Num_Frames=-2147483648
DurationInSecs=-2147483648
Duration=-577014:-32:-22.-7
Width=720
Height=480
Standard=NTSC
BitRate=0
AudioStreamCount=0
Audio1SampleRate=-1
Audio1Codec=NULL
Audio1BitRate=-1
Audio2SampleRate=-1
Audio2Codec=NULL
Audio2BitRate=-1 -
EndBoards: Can you ftp me a sample? You can use http://www.svcd2dvd.com/releases/MakeSample.zip and upload to ftp://Upload:SampleUploader@ftp.svcd2dvdmpg.com:7676/
Thanks for such a great tool, I've been using it for a while now with great results. I ran into one oddity today. I have a large TS file (13.7GB) that is 1280x1088. For some reason HDTV2DVD converts this to 352x480 so the resulting DVD only fills the middle third of the display. Is there anyway to force it to output 720x480?
I suspect the duration is such that the bitrate would be less that 3000kbs. When this is the case it is recommended that you create a half-d1 resolution - which is what HDTV2DVD does...
What is the duration? What was the encoded bitrate that HDTV2DVD chose?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Interesting. Can you post or email me your log?
************************* ProjectMetaData **************************
<HDTV2DVD DateTime="3/8/2006 12:09:54 PM"><AssetSet><Asset ID="91676418-379a-4cf2-93fd-66278b51f269" Path="D:\Extract" Filename="Titanic-.ts" /></AssetSet><Settings><General InitialAssetFolder="" InitialDVDFolder="" InitialProjectFolder="" DeleteS2DFiles="False" UseDVDShrink="False" /><Menu AudioEncoding="Silence_mpa" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="PAL" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" /><Process AudioEncoding="mpa" Chapters="Every 10 mins" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" /><Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" /><Burning BurningMethod="NONE" DVDDrive="" NeroWriteSpeed="" Eject="True" HighDVDCompat="True" VerifyDVD="False" DVDDecrypterPath="" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" /></Settings></HDTV2DVD>
Processing assets for DVD creation
=================== AV Details ===================
file=D:\Extract\Titanic-.ts
FormatName=mpegts
Num_Frames=349927
DurationInSecs=11675
Duration=03:14:35.9
Width=1280
Height=1088
Standard=NTSC
BitRate=10105
AudioStreamCount=1
Audio1SampleRate=48000
Audio1Codec=ac3
Audio1BitRate=384
Audio2SampleRate=-1
Audio2Codec=NULL
Audio2BitRate=-1
HDTV2DVDMPG: 2720kbs
Leaving source audio alone.
Using high bitrate matrices
Pass 1/1: Processing Titanic-.ts
12:09:55: ffmpeg version CVS, build 3276800, Copyright (c) 2000-2004 Fabrice Bellard
12:09:55: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-vhook
12:09:55: built on Sep 23 2005 15:20:26, gcc: 3.2.3 (mingw special 20030504-1)
12:09:55: Input #0, mpegts, from 'D:\Extract\Titanic-.ts':
12:09:55: Duration: 03:14:35.9, start: 0.295422, bitrate: 10105 kb/s
12:09:55: Stream #0.0[0x1000], 29.97 fps: Video: mpeg2video, yuv420p, 1280x1088, 65000 kb/s
12:09:55: Stream #0.1[0x1001]: Audio: ac3, 48000 Hz, stereo, 384 kb/s
12:09:55: Output #0, dvd, to 'D:\Extract\Titanic-_S2D.mpg':
12:09:55: Stream #0.0, -1.#J fps: Video: mpeg2video (hq), yuv420p, 352x480, q=1-31, 2720 kb/s
12:09:55: Stream #0.1: Audio: ac3, 48000 Hz, stereo, 384 kb/s
12:09:55: Stream mapping:
12:09:55: Stream #0.0 -> #0.0
12:09:55: Stream #0.1 -> #0.1
12:09:55: Warning, QMAT_SHIFT is larger then 21, overflows possible
13:46:25: [mpeg2video @ 00712860]ac-tex damaged at 46 45
13:46:25: [mpeg2video @ 00712860]Warning MVs not available
13:46:25: [mpeg2video @ 00712860]concealing 80 DC, 80 AC, 80 MV errors
14:29:30: [mpeg2video @ 00712860]ac-tex damaged at 44 56
14:29:30: [mpeg2video @ 00712860]Warning MVs not available
14:29:30: [mpeg2video @ 00712860]concealing 80 DC, 80 AC, 80 MV errors
14:30:45: [mpeg2video @ 00712860]ac-tex damaged at 35 57
14:30:45: [mpeg2video @ 00712860]concealing 80 DC, 80 AC, 80 MV errors
14:32:19: video:3124824kB audio:547322kB global headers:0kB muxing overhead 23.601896%
14:32:19: HDTV2DVDMPG: done.
14:32:19: Done: Processing assets for DVD creation
Authoring DVD Folders
14:32:19: Creating TitleSet # 1
14:32:19: SVCD2DVD: DVDfolders
Generating DVD folders please wait....
14:32:19: -->: DVDFolders creating VTS
14:32:19: -->: VTS 01
14:32:19:
DVD Folders: Processing D:\Extract\Titanic-_S2D.mpg...
14:35:24:
14:38:12:
14:38:12: Finalising DVD...
14:38:12: SVCD2DVD: DVDfolders
14:38:12: -->: DVDFolders creating table of contents
14:38:12: scanning D:\Extract\HDTV2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO
14:38:12: Finalising DVD...Done
14:38:12: Done: Authoring DVD Folders -
As i suspected. 03:14:35 works out as 2720kbs in order to fit onto DVD5.
To solve it have a look at https://forum.videohelp.com/viewtopic.php?p=1439017#1439017 but bare in mind that you are talking about HDTV2DVD and so the settings will be for "HDTV2DVD"
Or you could opt for the Dual Layer setting and then shrink the output with DVD shrink.
Bottom line is: putting 3 hours+ of anything (HDTV, avi, mpeg... etc) onto DVD will result in a low bitrate. In such cases it is recommended to use Half-d1 res. This is what SVCD2DVD & HDTV2DVD does BUT you can override this decision.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I'm trying to use this program but I had no luck at all.
One of the tw othings occur:
1. I Drag the file and nothing happens, no file is shown in the Assets
or
2. I receive a message fro mwindows saying: "ffmpeg.exe has encountered a problem and needs to close"
Any ideas on how to fix this ?
I've tried reenconding the file with VideoReDo, and didn't work.
I used Mpeg2Repair, one of the files I used couldn't be correct, the other could but even so, it won't work at HDTV2DVD.
I tried HDTV2MPEG2 and also, I had no luck.
Anyrhing else I could try ?
PS: I'm already giving a 5mb sample of the file: http://s52.yousendit.com/d.aspx?id=38SDQIRNF1WG31IOSK6LMQEAVZ -
AAC audio is not supported:
I will look to add this when i get the time.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
hi
I am relatively new to this, this may not be the place. Is it possible to keep the sub titles going from transport stream to DVD.
thank you
forestr -
In theory yes, but i have not built this in. Can you supply a sample of such a file so i can see what i need to do?
Hi
the files are large around 2 gb. I have not found a way to break it up and preserve the subtitles to upload a file. do you have any suggestions.
forestr -
from a bit further up the page:
https://forum.videohelp.com/viewtopic.php?p=1473878#1473878SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
you should be ok if choose PASV ftp in IE or your favourite ftp client (e.g smartftp from smartftp.com):
Hi ChrissyBoy..Originally Posted by ChrissyBoy
Sorry I never did this, I've been working LOTS of overtime lately and haven't had a chance to mess with any of this. I've made a 16MB sample file, but couldn't get into the ftp link you set up - either in IE or through my FTP client. Is the folder still set up? I do have passive FTP enabled in my IE and FTP Client.
I don't know if any of this helps, but just so you know this isn't a HighDef stream. It's a SD show that my mom wanted a DVD of. I captured off of my Motorola DVR via firewire.
Thanks! -
Can you try the ftp again - i had to rebuild my PC a while back and have only just set up the FTP. I have made a config change which may help.
HDTV2DVD 0.4 Vista
By CathyT in forum Authoring (DVD)Replies: 2Last Post: 28th Dec 2009, 13:01 -
HDTV2DVD does not load up TS-file
By feilofix in forum Authoring (DVD)Replies: 2Last Post: 12th Nov 2008, 14:25 -
HDTV2DVD - .TS wont load
By NotSoEasy in forum SVCD2DVD & VOB2MPGReplies: 11Last Post: 15th Mar 2008, 20:09 -
How to load .ts file into HDTV2DVD?
By JR.S in forum Newbie / General discussionsReplies: 2Last Post: 15th Nov 2007, 02:59 -
Audio is out of sync after using HDTV2DVD, how can I fix this?
By geek2330 in forum Newbie / General discussionsReplies: 20Last Post: 4th Oct 2007, 17:31
