Im using the new soundforge and wanted to know the best way to remove vocals off of a wav file to just have the instrumental???
Results 1 to 18 of 18
I assume SoundForge still uses directX plugins. If so, try this: http://www.analogx.com/contents/download/audio/vremover.htm
i put it in sonys plugin dir but cant pull it up. What am i doing wrong????? also yes sf still uses directx plugins
Once you download the installer, run it. Do not move anything to the sony directory. DirectX plugins do not really have anything to do with sony, other than Vegas can use them. Once installed, start up vegas, and on the audio timeline, add a filter. You could have one called "AnalogX vocal remover".
It looks like it needs to show up in the plug-in manager (Ctrl+Alt+0). To apply, it can be selected from the Effects Menu. Please verify!
i cant even see it on soundforge but i can in win amp the only thing is i cant control where it goes and cant find the file
is there another vocal remover out there and was this the same vocal remover for virtual dj software??????
i have both.... and i still cant pull it up in sound forge..... can someone plese help?????
All this work and I have a feeling you're going to be disappointed. There is really no way to remove vocals unless they're on another separate track. And it that's the case, then just don't use the vocal track.
If your vocals are already mixed down to your music it will be practically impossible to remove them. Any Plug-in you user wil most likely leave your music sounding like crap. If its a popular song you might be able to find a Karaoke version.
drink up....the world's about to end -
Well, you could do "the trick" manually - this is all the plugins do:
Take one channel, invert it, sum both channels to mono. Ta-da. Now you have your very own crappy sounding karaoke.
You can maintain some of the bass that gets removed by copying the original file, lowpassing it around 100Hz, and mix pasting that back in after the cancellation routine.
as was said by others, don't expect much. -
dam.... and i have tried like 2 different vocal removing softwares and they dont rip the right things out of the beat..... and it do sound really shhhhhhhhhh.......... oh well
Probably the best way to remove vocals is using Adobe Audition's center channel extractor. It has a vocal remover option that is definatly better then the invert and sum filter that most audio editors use for vocal removal. It still won't be perfect but a lot better then most audio editors vocal removal filters.
i will try it and let you know.... i really didnt wanna dl another big software but oh well.......
i was finally able to see that vocal remover in sf but it doesnt work???? did i so something wrong?????
VCD Karaoke (MPEG DAT file)- removing the vocals
By tsrusa2002 in forum Video ConversionReplies: 12Last Post: 22nd May 2011, 02:51 -
Removing Vocals in an MP3 file
By Shadowofthedarkgod in forum AudioReplies: 10Last Post: 4th Jan 2010, 05:35 -
cannot hear vocals only music
By nirbhayn in forum Newbie / General discussionsReplies: 4Last Post: 15th Jul 2008, 08:48 -
Remove Vocals from a cd/mpg
By Harmetheous in forum AudioReplies: 3Last Post: 18th Feb 2008, 16:14 -
Extracting vocals from an already existing song
By RushMaster in forum AudioReplies: 4Last Post: 9th Sep 2007, 22:16
