Hi all
I am running into problem after problem with adding 2 avi's 2 one DVD, First of all it wont let me join them using Virtualdub, it says they are different but they are 2 parts of the same film.
So then i used winavi to convert them to mpeg 2 and am using tmpeg author to put them on 1 dvd and its saying the bit rate is too high when i select the mpeg file i have just created with win avi
Help im completly stuck!
Thanks all
Closed Thread
I always get that message with Tmpgenc dvd author. Just ignore it and it should be fine.
Regards,
Chas
please don't create new topics for basicly same problems,
https://www.videohelp.com/forum/viewtopic.php?t=280062&highlight=
just reply to add more information.
Problems with ffmpeg adding subtitles to MP4
By videobill in forum SubtitleReplies: 3Last Post: 2nd Dec 2010, 18:49 -
problems with adding the sub file on VirtualDub
By yuunhaa in forum SubtitleReplies: 7Last Post: 25th Feb 2010, 11:39 -
problems adding 5.1 sound using virtualdub mod??
By pete7769 in forum AudioReplies: 4Last Post: 24th Jul 2009, 15:45 -
Adding Subs to Avi
By ill_kuma in forum SubtitleReplies: 7Last Post: 9th Feb 2009, 20:02 -
Having problems adding a subtitle to a video...
By Johnathan in forum SubtitleReplies: 1Last Post: 15th Apr 2008, 07:35
