I have coverted my AV camcorder video to mpeg files and then burned them on to DVD. My Yamada DVD player plays them fine until i hit the 20 min area, it then just stops and goes to the next file on the disk. I think that this 20 min is about a gig of file. This occures on all the files, i only get the 20 mins.
Any ideas would be welcome.
Thanks.
are you authoring to a real dvd (with video_ts and vob,ifo file) or just burning the mpeg files(mpeg playback could be very different from player to player) ?
No just burning the MPEGs, done this loads of times before and never had this problem. I might just convert them to Divx to save space and all these problems. I am am very curious as to why this is happening.
You player obvious can play direct MPGs. However that is not the proper way to create a DVD. You must author it inan authoring program. Then and only then will you have a proper REAL DVD. I don't have a clue what is going on ith your MPGs burned as data on a disc.
No DVD can withstand the power of DVDShrink along with AnyDVD!
WMP6 Catastrophic Failure / MPC Stops Playing - MPEG Files
By jeanpave in forum Video ConversionReplies: 0Last Post: 17th Apr 2010, 01:25 -
Playback of MPEG-2 movie burnt on a DVD stops after some time.
By ssukuru in forum Newbie / General discussionsReplies: 4Last Post: 16th Apr 2010, 04:31 -
Audio and video off if captured longer then 10 mins?
By Ghtpua in forum Capturing and VCRReplies: 4Last Post: 7th May 2008, 12:39 -
MPEG video stops half way through playback
By lpmitch in forum Software PlayingReplies: 4Last Post: 4th Apr 2008, 23:15 -
How to burn a 157 mins. video on a 120 mins. dvd
By Gerald Sr. in forum Authoring (DVD)Replies: 2Last Post: 20th Jan 2008, 03:19
