I have had an Optorite DD0405 on the shelf for a while and finally installed. Seemd to burn okay and playback was okay (for me) .
I notcied issues when I tried to erase CD-RW , it would not erase even if it said it did.
Then terror struck. A customer that I burned disk for said they could not read theirs. I said try another DVD player. They did and get part way through. I off course offered to replace the disks. I have a master at home. Great...EXCEPT it too was created with the optoriteand when I try to copy my own disk to the hard drive (on any machine) about 1/3 of the way through VTS_VOB 03 always, iit hangs !!! Eventually CRC error.
This is pathetic. If I cannot copy from the clients disk then I have to reload tapes, go back to the beginning and RE-EDIT an entire wedding. Thanks alot optorite.
Anyone hear of this ? Anyone know how to get past the read error ? Arrggg
And thanks in advance......Rob
I assume you have tried to read the disc in another drive besides the one it was written with and the customers drive? I have had this happen before. For me it was not a defective drive it was crappy writing software. I have been ble to get data off of discs with these problems by trying multiple drives that I own.
The real answer lies in completely understanding the question! -
More information please. Burning software, media used (using dvd identifier or dvdinfopro) etc...
Info
Media - Same - Says Mitsubishi
Vobs, etc created with DVD arch.
Burned with Nero 6.
Not the media, nero or DVD arch.
Its the burner. I tried several tests with all of the above. ONLY those created on that burner have a problem, all somewhere in VTS_03_02
Gets CRC error and now I am hosed because the wedding I burned on there cannot be copied back. Sooooo
I have to reload all tapes and re-edit the whole damn thing.
Thanks OPTORITE
I will have to be sure to add to the reviews so folks will BE WARE and BE AWARE
CRC Errors in Blu-ray burns...
By Lathe in forum Blu-ray RippingReplies: 12Last Post: 13th Dec 2010, 00:28 -
New PC Burns With Errors
By NOIC in forum DVD RippingReplies: 22Last Post: 29th May 2009, 13:12 -
CRC errors when copying DVDs
By Shadowofthedarkgod in forum Newbie / General discussionsReplies: 7Last Post: 1st May 2009, 03:59 -
CRC Errors when copying to HD
By terrypin in forum Newbie / General discussionsReplies: 2Last Post: 2nd Feb 2009, 07:24 -
Bad Burns
By jalfirov in forum Authoring (DVD)Replies: 1Last Post: 16th Aug 2007, 04:23
