I've got a .bin file which I wish to burn. I've made a .cue file in notepad, but when Nero tries to burn the data, it says the the total size exceeds the capacity of the CD. I've enabled overburn but to no avail. If i burn the data directly (ie not using a cuesheet) then it fits fine onto the same CD. I need to use the .cue as I want the CD to auto-boot when I switch on my PC. How do I know if I'm creating the .cue file correctly?
BTW I've tried Fireburner (which can't even see the .cue) and Discjuggler (which has the "start" button greyed out, so I cannot start the burn process.) Any help is appreciated.
You might check this thread on the Afterdawn site:http://forums.afterdawn.com/thread_view.cfm/7976
There is a free program called CUEATOR which will create the .cue automatically. Try Google, I'm sorry I can't get you the link but I am @ work...
"Quit Playing With The Clock..."
Rudy - Funhouse pinball game -
Or MakeCue
No DVD can withstand the power of DVDShrink along with AnyDVD!
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 09:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
