Hey, I was told when setting up a wireless network that it is recommended that you wire the router directly to the computer. My computer doesn't have a place to plug in that specific wire type. I have something similar to this plugged in my computer.
I was wondering what the advantages of setting it up with a wire directly would be, would it be more stable?
Thanks for reading this
Stability depends on the wireless connection. Your speed will be twice as fast if your wired NIC supports 100Mbps or up to 20 times as fast if it supports 1000Mbps. If the router is close by, I'd recommend hard wiring the close by machine while all others in the network are wireless. Typically, the computer nearest the router is the main computer in a household and will benefit from the increase in speed. NIC 10/100/1000 cards can be purchased for under $20. I just purchased threeTrendnet 10/100/1000 wired NICs for under a penny. Actually, when I get the rebates back I'm actually being given a penny for each one purchased (12.99 - 13.00 rebate).
You can remove the wireless card and replace it with a PCI wired NIC with no loss to expansion slots. -
Alright thanks for the info. One of my main concerns is that my media will get corrupted if I have done the networking incorrectly. As long as it transfers should it be ok?
Yes. The transfers will be fine using either wired or wireless or even a combo of the two in your network. It is typical that the first computer nearest the wireless router is hardwired for the express purpose of speed.
Wireless Network for Multimedia
By DarrellS in forum Media Center PC / MediaCentersReplies: 0Last Post: 19th Feb 2011, 00:22 -
Wireless network problems
By Tbag in forum ComputerReplies: 3Last Post: 15th Nov 2008, 20:52 -
How do I protect my wireless network from my neighbors?
By Xenogear900 in forum ComputerReplies: 15Last Post: 4th Dec 2007, 19:33 -
how to limit speed of users on wireless network (router-lan-wireless)
By deejay.2001 in forum ComputerReplies: 5Last Post: 2nd Nov 2007, 23:56 -
xbox-1 wireless network?
By stackner in forum ComputerReplies: 1Last Post: 21st Jul 2007, 04:25
