wel im burning anime,i set it to 16:9 but the subs are cut off, so i set my player to view it in 4:3. what should i do to make it the subs viewed ok on tv,in pc its ok. im using winavi video converter and DVD Architect 3
what kind of subs? switchable subtitles that you add? or is the subtitles permanent in the anime video source?
permanent (?) subtitles made by anime fansubs.i can view the sub fully when i view it as 4:3.but i encode and burn them at 16:9
ok,il try to post it.on the pc's screen,it fine,but on tv its cut off.il post it later or tom
Hard subs are not much to do about without reencoding, if they where placed wrong (too low) to begin with. Seems like a common problem with fansubbed Anime, this. Either the one subbing it didn't know what he/she was doing, or it's only intended for computer viewing. (TV's leave some of the picture outside the visible are (how much depends on TV) - something taken into account by people who create stuff for TV. It even got it's own name: "Overscan").
If you reencode the AVI, you could add some black border bottom (and top?) to compensate for overscan. I doubt WinAVI allows for suce fine tuning, but a "real" mpeg encoder sure do.
/Mats -
Now, that's a toughie! There are so many to choose from. Take a look unde Tools, the DVD section.
Been using TMPGenc and MainConcept myself, but since I like free software, lately used QuEnc (which requires some AviSynth skill).
Procoder use to rate highest qualitywise, CCE is the speed deamon - You simply have to make that judgement yourself. Most commercial encoders have trial versions.
Since you're going to do some filtering (resizing an border adding) you might be best off, learning AviSynth, which in turn makes QuEnc a good option.
/Mats
Subtitles in Final Cut or other software?
By perik in forum SubtitleReplies: 2Last Post: 10th Dec 2009, 08:02 -
How do I cut TS file and keep Teletext/DVB subtitles ???
By boulder in forum DVB / IPTVReplies: 3Last Post: 30th Aug 2009, 18:50 -
Final cut pro and subtitles
By akiraku in forum MacReplies: 7Last Post: 6th May 2009, 17:31 -
Subtitles cut off on tv. More than just overscan?
By rayden54 in forum Newbie / General discussionsReplies: 9Last Post: 13th Feb 2008, 11:20 -
Subtitles getting cut off
By shockaholic in forum Video ConversionReplies: 2Last Post: 25th Oct 2007, 10:05
