Hi, I have a weird problem. I tried to cut this mpeg file using mpeg tools in tmpgenc (the opening and ending so the file will be smaller) and the result doesn't have any sounds. The original has the sound though. I tried extracting the audio from the file using vdub but an error msg came out instead. Tried using goldwave too and it worked, but then when I multiplex with the video file, another error msg came out. Something like illegal mpeg outstream. Is there a way to solve this? Thanks.
Must have AC3 or WAV or some non-MPEG audio.
Audio Problem with KMPlayer: Sound Disappeared
By devilcoelhodog in forum Software PlayingReplies: 2Last Post: 6th Jan 2012, 19:15 -
Pinnacle 12: Project disappeared
By avz10 in forum Authoring (DVD)Replies: 1Last Post: 11th Apr 2011, 17:41 -
titles disappeared after conversion
By izzykatz in forum Video ConversionReplies: 3Last Post: 3rd Feb 2009, 16:25 -
Task Manager has disappeared
By mysts in forum ComputerReplies: 12Last Post: 6th Apr 2008, 08:51 -
Lite-On 1673S disappeared...
By blasedeviant in forum DVD & Blu-ray WritersReplies: 11Last Post: 7th Feb 2008, 20:00
