i have a season of a myth busters that was ripped from a dvd and converted to xvid. i want to put the season back on a dvd. when i use dvdsp (with the quicktime xvid codec) to burn the files, the image would be over 20 gigs. obviously the original dvd wasnt 20 gigs. since they were converted from .vob to xvid, it seems like there should be a way to reverse the proccess. is there a way to do this and keep the image small enough to fit on a dvd-r (or a dual layer dvd if necessary)?
-BjTheClown
Take the xvid file, and place it into Compressor.
Using a Bitrate Calculator, figure out the total length of
the xvid, and set the target of the DVD to 4300.
Set and encoding Preset in DVDSP 3 for that,
Process with Compressor creating your .m2v and .aiff
files.
Import the .m2v and .aiff files into DVDSP 3, build a menu,
and then burn."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
20 GB sounds quite reasonable for the retail DVDs: MythBusters Season DVD Sets: 13 episodes on 4 DVDs: 13 x 50 minutes = 10 hours 50 minutes.Originally Posted by BjTheClown
ah, i didnt take that into account. i didnt think it would be a dvd SET, i just assumed it was one dvd. damn. i was hoping to get them all on one dvd with near-original quality. i thought if the dvd company can do it, why cant i? but the dvd company doesnt do it. thanks for pointing that out. i guess ill just get used to buying dvds in bulk.....
-BjTheClown
DVDSP output multiple copies?
By MikieV in forum MacReplies: 10Last Post: 8th Dec 2010, 12:10 -
DVDSP Disc only plays on MAC and not my DVD player
By jandajones in forum MacReplies: 3Last Post: 1st Oct 2010, 03:30 -
Livetype tot DVDSP help
By whiff79 in forum MacReplies: 3Last Post: 14th Mar 2010, 10:23 -
DVDSP Authored DVD - Cleaning the Code for replication?
By Adam Bolt in forum MacReplies: 2Last Post: 20th Jun 2007, 03:45 -
Motion&DVDSP-Square/Rectangular Pixels
By stretchweider in forum MacReplies: 4Last Post: 5th May 2007, 18:41
