I've been looking around for a solution to this issue and havent found one. I even asked a couple guys in the Apple store recently.
I am a new Mac user but I cant seem to do something with DVDs that I'm able to do on my PC. On my PC, with Nero's NeroVision express, I can take a few DVDs and combine them into one. The quality is reduced, but the kids dont mind.
I rip the DVDs and then import them into NeroVision Express. I can then make menus, buttons, etc.
I cant seem to find a way to do this same thing on my iMac. I've seen apps that can shrink a 9GB DVD to 4.7GB and even an app that can take 2 DVDs to one. But I cant find an app for the Mac that does what NeroVision does.
I also cant seem to find a way to change the resultant DVD type for the output in iDVD. Maybe I could convert to AVI and then import into iDVD. I think the mode I'm looking for is "Half D1".
Anybody have any ideas? I'd hate to keep using my PC for this task.![]()
Easiest:
Mac The Ripper to Rip Main Title,
FFMPEGX to process to .Mov,
rinse repeat rinse repeat
Open Toast, drag and drop .mov in toast
Burn in Toast.
Harder:
FFMPEG to process to .DV,
rinse repeat rinse repeat.
Bounce into Compressor, set Bitrate to make
all movies fit to standard DVD-5.
Author in DVDSP 3, save[build] project.
Open Toast, Burn in Toast. -
Converting DVDs to half D1 will take a few hours per DVD, depending how fast your mac is. You'll be able to fit around 5 or 6 hours onto a DVD-R. Unfortunately I don't believe there is any one-stop-solution to take your video_ts folders and output a single video_ts folder containing a bunch of seperate half-D1 videos. You can encode them to half D1 individually with ffmpegX (unselect 'author as dvd', you wont need it), but then you'll have to use the mpg files in Sizzle/DVDSP/Toast to make a menu.Originally Posted by NRaygun
What/How to combine DVDs
By fordgrl99 in forum Newbie / General discussionsReplies: 1Last Post: 26th Oct 2011, 12:16 -
How do I combine DVDs?
By sldvd in forum Newbie / General discussionsReplies: 2Last Post: 31st Mar 2010, 23:38 -
Combine DVDs
By mike202513x in forum Newbie / General discussionsReplies: 2Last Post: 16th Feb 2010, 13:56 -
Ripping chapters from several DVDs to combine onto one
By arianek in forum MacReplies: 2Last Post: 21st Jul 2009, 10:14 -
how to combine dvds without using dvdremakepro
By Onceler2 in forum DVD RippingReplies: 3Last Post: 3rd Mar 2008, 14:58
