Hi, I just tried for the first time to convert 2 xvid dvd rips to dvd using the great svcd2dvd program. I did 2 passes, everything came out excellent, but the audio is out of sync. How exactly do I fix this, I don't have the xvids anymore, but is it possible to rip the dvd back, and fix the audio sync without too much hassle?
Thanks in advance.
Is the sync out by an certain amount right from the start?
Well then have a look at: https://www.videohelp.com/forum/viewtopic.php?p=1338598#1338598
Thanks, I don't have the xvid files anymore, do I have to rip the dvd to xvid now, and than try again or is their a way to import the dvd into that program?
avimux only takes avi's as input. I suspect that without the original xvids you are snookered...
I did it again, it worked. Thanks ! love this program, worth the money, just don't go commercial and sell it to a big corporation whore !
I wish.... (only joking!!)
Shrink Xvids to fit episodes on DVD
By Wolfbrain in forum Video ConversionReplies: 5Last Post: 20th Apr 2009, 11:40 -
Some XviDs play choppy on standalone DVD player, but absolutely fine on PC
By udaykhan in forum DVD RippingReplies: 5Last Post: 15th Jan 2008, 11:09 -
The last vts file screws up why?converting xvids?using svcd2dvd!!!
By hacksawman in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 8th Oct 2007, 16:30 -
Problem Divx's & Xvids
By ramses505 in forum Video ConversionReplies: 3Last Post: 8th Oct 2007, 09:39 -
Is this how to make Hi-Def xvids?
By Topher5000 in forum Video ConversionReplies: 4Last Post: 17th Sep 2007, 15:05
