My video capture card is a twinhan dtv recieves dvb-t and analog tv. Ihave plugged in the in and out ariels to the back of the capture card along with the same ariels into the back of my vhs recorder. Iam trying to capture my wedding video and to put it onto dvd. For some reason the capture card screen is blank even after tuning it in?
I have premiere pro and encore
Any idea's
Kind regards Josel
You must connect the OUTPUT of your VHS ( probably s-video or composite video) to the equivalent input on your card. The aerial output on your video is simply a Pass-thru to forward on the (broadcast)existing signal to your telly even when your video is switched off, kapitsch?
The electronic components of the power part adopted a lot of Rubycons.
Capturing via capture card or DVD recorder
By mark23 in forum RestorationReplies: 5Last Post: 9th Apr 2012, 11:20 -
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 12:27 -
targa dvd/vhs recorder won't recognise dvd+rw discs.
By steve6 in forum DVD & Blu-ray RecordersReplies: 13Last Post: 31st Jan 2011, 16:04 -
DVD recorder wont recognise disks
By ruthybear in forum Newbie / General discussionsReplies: 1Last Post: 4th Nov 2010, 13:16 -
Which $150 or under capture card for VHS/S-VHS -> computer?
By HDClown in forum Capturing and VCRReplies: 25Last Post: 16th Apr 2010, 22:16
