Closed Thread
  1. Did anyone have "failed to write xxx.iso file, incorrect parameter" error message when you use dvdshrink? How do you fix this problem?
  2. You can't!
    The software does not work on some external devices, such as a External Hardrive, etc...
    For it to work properly with shrink, you have to have it directly in a file on your computer for using it and then transfer it back where you had it or like to place it.
    This is the only way if you get the message of Incorrect parameter in DVD shrink.
    Try this and see!
    Please check the date when you post. This was posted 8 years ago...
  4. Thanks found it very useful.
  5. Agreed. Cheers to Steeledragon for Posting an 8-year late Answer! I spent a half hour on other sites b4 finding this Simple Fix!!
    (hopefully the OP found an answer back in 2005. I was about to buy an alternate $40 program b4 finding this answer)
  6. I'm a Super Moderator johns0's Avatar
    canada
    Thread closed.
