The volume on a DVD r that I have is very, very low. I put the TV program on my hard drive. I decided to try to increase the volume and reduce hiss in Adobe Audition. I used that program to seperate the audio from the video. I cleaned the audio up to my liking. I saved the improved audio as a WAV file. When I put the video with the fixed audio in Tsunami MPEG DVD author and preview the movie in edit clip the audio is about 2-3 seconds ahead of the video. Is there someway to re-sync them in Audition? I tried looking in the guides here and google but no dice. I was so close to getting improved sound now this last road block stands in my way. Any help would be appreciated.
You could insert the required amount of silence in front of the audio (in waveform view) to sync them up again. It would be a bit trial-and-error, but it can work.
Audio Sync Issues!!!!
By earthXDust in forum EditingReplies: 3Last Post: 30th May 2011, 00:23 -
audio sync issues.................
By landocass in forum Newbie / General discussionsReplies: 1Last Post: 26th Jul 2010, 17:48 -
Audio Sync Issues From AVI
By tyders in forum Newbie / General discussionsReplies: 5Last Post: 14th Apr 2009, 10:36 -
Audio sync issues
By andy99 in forum EditingReplies: 7Last Post: 16th Sep 2008, 23:47 -
Audio Sync Issues
By Pinata in forum DVD RippingReplies: 2Last Post: 28th Jan 2008, 09:38
