Does any body knows:
What is better to work in my DVD project mpeg2 or avi?, because mpeg is not heavy as the avi ...
So I edith my DV (avi) files in Adobe Premiere, when a I finish, I had wondered: what is better to export in mpeg2 or avi for DVD Encore (Project)![]()
Yep, you'll need MPEG-2 at some point if your target is a DVD to be playable in all settop DVD players.
<insert pandora's box (settops capable of playing divx/xvid) here>
That said, you only want to convert to MPEG-2 once if you can help it, so if all you're doing in Premiere is editing, then using Encore to do the encoding and authoring in one, then yes, IMHO you're better off exporting back out using DV-AVI.If in doubt, Google it.
mpeg2 (4:3) to avi (16:9)
By kouras in forum Video ConversionReplies: 3Last Post: 3rd Feb 2009, 09:53 -
dv-avi(mpeg2) to avi compression
By nivek_nayr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 12th Feb 2008, 08:44 -
MPEG2 to AVI conversion.
By fl3tty in forum Video ConversionReplies: 5Last Post: 4th Dec 2007, 00:31 -
AVI to MPEG2 conversion
By Alexstarfire in forum Video ConversionReplies: 8Last Post: 6th Aug 2007, 18:42 -
avi to mpeg2
By n2lakers in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jun 2007, 14:56
