Is there a media player that lets you adjust the audio/video sync while its playing? Because I have a video that is synced half-way through, and then they go off a little bit.
Thanks.
Results 1 to 11 of 11
make install.
If you are downloading a pre-compiled version, then there is no install. Just unpack. You can also edit the conf file to your liking, specifying default languages, audio/video filters, enabling the OSD menu, setting fullscreen, number of audio channels, set default DVD drive, etc.
Drop a media file on mplayer.exe and it will play. -
I must be stupid, I can't unpack any of the pre-compiled ones. Their all weird files that I can't open.
Why did they make things so complicated? -
Well all my compiles are compressed with 7-zip which is no more complicated than zip or rar, it just compresses better. Less complicated I would say than downloading a whole bunch of seperate files.
http://www2.mplayerhq.hu/MPlayer/releases/win32/MPlayer-mingw32-1.0pre7.zip
Download that and extract it into a directory on your hard drive. Then drag and drop your file onto the mplayer.exe file.If in doubt, Google it. -
Cool, thanks jimmalenko...
somebody knew what i was talkin about. -
Originally Posted by celtic_druid
! Drag and drop is much faster and easier.
[note from man_page on topic: Each click of + or - should adjust audio delay by +/- 0.1 seconds (one-tenth of a second).]
ffdshow audio and video out of sync on Windows Media Player
By nazopo in forum Software PlayingReplies: 0Last Post: 22nd Dec 2010, 22:17 -
Software that adjusts color and brightness of video
By ericdunn in forum Newbie / General discussionsReplies: 5Last Post: 24th May 2010, 06:48 -
Need help with audio recording software that adjusts microphone input
By jimcornetet in forum AudioReplies: 3Last Post: 24th Apr 2010, 01:01 -
MKV to AVI, audio sync issue, not on PC, but on HDD media player
By danowat in forum Video ConversionReplies: 1Last Post: 12th Nov 2008, 04:53 -
Audio track out-of-sync with DivX/XviD media file after video was split
By robo5050 in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2008, 03:30
