I tried to burn a movie I have and these are the files in the directory:
DIRECTORY LISTING:
VTS_02 - Stream Information.txt
VTS_02_0.IFO
VTS_02_1.VOB
VTS_02_2.VOB
VTS_02_3.VOB
VTS_02_4.VOB
VTS_02_5.VOB
Within the stream information text file is this:
0x20 - Subtitle - Hrvatski - [SubPicture 01: Wide/Letterbox] / LBA: 21847 / PTS: 00:00:44.573 / Delay: 44440ms
0x21 - Subtitle - Czech (Ceske) - [SubPicture 02: Wide/Letterbox] / LBA: 21846 / PTS: 00:00:44.573 / Delay: 44440ms
0x22 - Subtitle - Dansk - [SubPicture 03: Wide/Letterbox] / LBA: 21845 / PTS: 00:00:44.573 / Delay: 44440ms
0x23 - Subtitle - English - [SubPicture 04: Wide/Letterbox] / LBA: 21844 / PTS: 00:00:44.573 / Delay: 44440ms
0x24 - Subtitle - Suomi - [SubPicture 05: Wide/Letterbox] / LBA: 21843 / PTS: 00:00:44.573 / Delay: 44440ms
0x25 - Subtitle - Hebrew - [SubPicture 06: Wide/Letterbox] / LBA: 21842 / PTS: 00:00:44.573 / Delay: 44440ms
0x26 - Subtitle - Magyar - [SubPicture 07: Wide/Letterbox] / LBA: 21841 / PTS: 00:00:44.573 / Delay: 44440ms
0x27 - Subtitle - Islenska (Icelandic) - [SubPicture 08: Wide/Letterbox] / LBA: 21840 / PTS: 00:00:44.573 / Delay: 44440ms
0x28 - Subtitle - Norsk - [SubPicture 09: Wide/Letterbox] / LBA: 21839 / PTS: 00:00:44.573 / Delay: 44440ms
0x29 - Subtitle - Polish - [SubPicture 10: Wide/Letterbox] / LBA: 21838 / PTS: 00:00:44.573 / Delay: 44440ms
0x2A - Subtitle - Portugues - [SubPicture 11: Wide/Letterbox] / LBA: 21835 / PTS: 00:00:44.573 / Delay: 44440ms
0x2B - Subtitle - Svenska - [SubPicture 12: Wide/Letterbox] / LBA: 21834 / PTS: 00:00:44.573 / Delay: 44440ms
0x2C - Subtitle - Turkish - [SubPicture 13: Wide/Letterbox] / LBA: 21833 / PTS: 00:00:44.573 / Delay: 44440ms
0x2D - Subtitle - English - [SubPicture 14: Wide/Letterbox] / LBA: 16697 / PTS: 00:00:25.413 / Delay: 25280ms
0x80 - Audio - AC3 / 6ch / 48kHz / DRC / English / LBA: 9779 / PTS: 00:00:00.045 / Delay: -88ms
0x81 - Audio - AC3 / 2ch / 48kHz / DRC / English / LBA: 9780 / PTS: 00:00:00.045 / Delay: -87ms
0xE0 - Video - MPEG-2 / 720x576 (PAL) / 16:9 / Letterboxed / LBA: 9774 / PTS: 00:00:00.133 / Delay: 0ms
I get errors from Nero when I burn the files to DVD because files are missing, but I burned anyhow to see what happens. The errors I get from Nero is "DVD-Video files compliance test failed. The resulting DVD-video might be unplayable. Do you want to continue?" Also from Neros event log, it's showing: "VIDEO_TS.IFO is not present, VIDEO_TS.BUP is not present, VTS_02_0.BUP is not present." . Standalone DVD player doesn't read dvd, yet Power DVD on the pc can read the video files fine. How can I get the BUP files that I require for this to function correctly in a DVD player? Thank you.
Closed Thread
Hi carstunts,
Welcome to the forum.
Rip the files you need from the DVD the other files came from.
DVDDecrypter will do the job if the disc is encrypted, or just "drag and drop" in Windows Explorer if it's not.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Um, they were obtained by other means
, not by another dvd.
So I'm unable to get it from another source. I'm aware that DVD Decrypter can decrypt dvds if they are encrypted, but this is a different situation. Any way to recreate the BUP and IFO files I need?
You can discard the stream information txt, its not needed. What you need is VOB, IFO, and BUP as well as a VIDEO_TS file. BUP just means BackUP. So make an additional copy of IFO and rename to BUP.
I would rename all the VTS_02 to VTS_01, hence change all the number 2 into 1.
Use DVDFab 0.17 (old freeware version, the link will provide it) to create the necessary VIDEO_TS files.
Originally Posted by carstunts
Warez did you get these from ?
Anyway ...
I'd renumber your VOBs from VTS_02_1.VOB - VTS_02_5.VOB to VTS_01_1.VOB - VTS_01_5.VOB and then follow the instructions here:
http://members.dodo.net.au/~jimmalenko/test.htm#ifoeditIf in doubt, Google it.
.ifo/.sup subtitle pair - what's in the .ifo?
By MilesAhead in forum SubtitleReplies: 2Last Post: 4th Mar 2010, 23:02 -
no more VOBs - but what else?
By slimselecta in forum DVD RippingReplies: 1Last Post: 3rd Aug 2009, 06:50 -
Convert non-compliant VOBs to "good VOBs"
By pmolson in forum Video ConversionReplies: 3Last Post: 24th Oct 2008, 10:52 -
Can I edit video_ts.ifo to link missing vobs to DVD?
By Srivas in forum Authoring (DVD)Replies: 1Last Post: 21st Jun 2008, 10:39 -
4 separate IFO files > one IFO to govern the full .VOB video
By Salva Veritate in forum EditingReplies: 4Last Post: 20th Aug 2007, 13:38
