junkmalle,
I tried the beta version of GSpot and yes it does show the interleave. Thanks for the info.
pinetop,
Are you saying that each chunk has only ONE stream either 0 or 1? All the interleaved files I made shows two streams per chunk as in the Batman trailer.
It would be interesting to know what the beta version of GSpot says.
Regards,
Chas
Results 31 to 37 of 37
I did a dub with VirtualDubMod.
Checked it with Hex Editor for having both streams. It did.
Still no audio. -
Is uncompressed PCM an option with VirtualDub ?
My last dub shows PCM on the player, before it was showing MP3. -
It's the default if you're not in audio full processing mode. Be sure to convert to 48 KHz, 16 bit, and Stereo, with High Quality checked. You're file is going to get a lot bigger.Originally Posted by pinetop
Thats what I did during the last dub. The file went from 799mb to 1.2GB.
Still no luck on the audio.
Increasing Audio volume on AVI/DivX/Xvid with AC3 Audio
By Spacedementia87 in forum User guidesReplies: 21Last Post: 24th Dec 2021, 08:21 -
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 14:35 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14 -
Intermediate codec and xvid question, and xvid to wmv.
By ^xRun^ in forum Video ConversionReplies: 9Last Post: 22nd Jul 2008, 18:13 -
Iso to Xvid Question
By boing in forum Newbie / General discussionsReplies: 2Last Post: 9th Jun 2007, 00:05
