Since my cable provider upgraded their channel guides on my Motorola PVR 6412, I can no longer dub from the Motorola PVR to my Toshiba DR2 as I NOW get a copyright error...
Is there a fix for this....??? Or can someone recommend a DVD recorder that can capture copyright material....
TIA
Kenmo
Results 1 to 20 of 20
Do a search on this site. I have seen several references to a device that can fix your problem, but since I don't need it, I don't really remember much about it, like, for example, the name of the device or the company.
Nyah Levi -
I also have a Toshiba DR2 , all need is a Sima CT-2 use it from Toshiba DR2 to Cable/Sat Box, it takes out all the Copyright Stuff/ MV . I hope this is for personal usage not for Resale.
Originally Posted by Marvingj
Do all DVD recorders support this copy protection....??? I thought I read elsewhere there were a few makes/models the circumvented this...
The Video Filter also allows you to backup your video collection to the Toshiba.
What is the price of this filter....???? Can I purchase one in Canada...???
Look at this thread from over in the Capture forum:
https://www.videohelp.com/forum/viewtopic.php?t=221797&highlight=cgms
about halfway thru the thread waverboy posts several links to what you are searching for. good luck -
When I connected my computer with an Hauppauge PV250 capture card, I was able to capture recordings on my Motorola to my computer's hard drive.... So it must be the Toshiba DVD recorder that is having issues with the upgrades to the Motorola....
Thanks OneSickPup for the link...but for the price of the filter I MAY be able to purchase another DVD recorder that is not as picky as the Toshiba about copyrighted material....(any thoughts).... -
Wish I could be of more help but honestly I don't know what advice would be best for your situation. I studied up a bit on CPRM/CGMS only because I thought it would effect me. As it turns out, my Comcast cable provider still is not passing the CGMS-A flag even though they do in other parts of the US. I still record any HBO digital channel without incident. Never tried PPV as we rarely ever use that service. Maybe someone else with better practical experience will happen along and share some advice.
One other thing. I may be incorrect but I think the Hauppauge PVR250 and PVR350 cards are known to ignore copy protection - to what degree I do not know. Might check over in the capture forum for more info on that. -
No problem at all...you have been very helpful....
I thought I read a post once my Lord Smurf where he suggested there were a few DVD recorders that used or shared hardware with the Hauppauge cards... I maybe wrong though..... -
Just spoke with a technician at Eastlink (my cable provider)....the firmware upgrade to the Motorola 6412 is causing this problem....Apparently it is by Motorola's design....
An expensive but excellent solution would be a full frame TBC (Time Base Corrector).
The AVT-8710 is about $190 USD
The DataVideo TBC-1000 is about $290 USD
Those are the cheapest Full Frame TBC devices that the hobbyist can purchase. After that they go up to around $1,000 USD +
A TBC will "re-sync" the video and as a "side effect" it will remove ALL forms of copy protection. There are many threads about just what a TBC is and exactly what it does.
I don't know about Canada but the USA based website B&H PHOTO & VIDEO has both of these devices for about as cheap as they can be purchased.
Just picked up a LiteOn DVD-R/-Rw +R/+Rw at Walmart for $164.00 (Canadian) and it records fine (so far) from the Motorola... Go figure...
Thanks all for the replies... -
No problems yet with the new LiteOn...able to record channels from the Motorola I could not with the Toshiba... I've also been able to rip the LiteOn records to my computer's hard drive and re-author to another DVD-R...
I love how the DVD+R/+RW in the LiteOn don't have to be finalized for my computer to read them.... However the LiteOn does not allow for fine tuning of various recording modes, it only has pre-defined 1hr, 2 hr, 4hr and 6hr... However it does record VCDs & SVCDs as well as audio CDs... This unit is COOL.... -
Originally Posted by kenmo
There is a hack for (some?) models of LiteOn units that do "open up" a 3 hour mode. I think LordSmurf and/or GShelley know where to get it.
- John "FulciLives" Coleman
P.S.
Actually the WALMART unit was ILO but that is still a LiteOn ... just with a different "name" on it."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Has anyone else had success with dubbing copyright broadcasts with the LiteOn 5005...????
Is there a firware hack for my Toshiba DR2 to enable it's ability to dub copyrighted broadcasts....??? -
Secret Copyright Treaty Leak: ISPs Worldwide to Become Copyright Cops
By joepic in forum Latest Video NewsReplies: 17Last Post: 5th Nov 2009, 10:05 -
Toshiba DR2 Won't recognize DVD-RAM any more
By jpc82 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 27th Dec 2007, 09:31 -
Toshiba Error E-25 Message
By anichan in forum DVD & Blu-ray RecordersReplies: 5Last Post: 21st Oct 2007, 22:48 -
Showing Movies & copyright laws
By pepegot1 in forum Newbie / General discussionsReplies: 13Last Post: 12th Sep 2007, 17:57 -
AT&T Announces Plans to Filter Copyright Content
By BJ_M in forum Off topicReplies: 1Last Post: 13th Jun 2007, 21:45
