I had some footage captured in Pinnacle at my church. The audio portion was fed into the camera from the sound board. At first the input was way too high but was later corrected. The problem I have is that when I turn down the loud part of the video the parts after the the sound was corrected on the sound board is too low. I can't figure out how to correct this. Any thoughts. I tried to the video as two seperate projects then join rejoin the but I haven't been able to figure it out.
Open your project in the storyboard view, go to either the part where the sound is too high or the part where it is too low, with your mouse pointer, click on the audio stream, left click on the stream itself and drag up or down, this should allow you to adjust the volume. It's been a while since I used the program, but I am pretty sure that that is all you need to do.
I am sorry, I opened an old project in Studio9, it is timeline view that you need to be in, not story board, right underneath the video portion, is the audio stream, this is where you need to adjust the sound(provided your audio and video were captured together) and it is as simple as left clicking the stream and dragging it up or down while holding the left button.
If you need any further assistance, I wil check back later. -
When you adjust the volume in one part all the ohter part ajust at the same time
Whoa I just figured it out. Didn't realize if you click on the sound line it puts a little dot and then you can move just that part.
Pinnacle Studio 9 sound on menu
By JaceKiwi in forum Authoring (DVD)Replies: 4Last Post: 29th Jun 2009, 02:31 -
sound problem using PINNACLE Studio MovieBoard Ultimate S12 PCI
By Gswiss in forum Capturing and VCRReplies: 2Last Post: 12th Dec 2008, 14:11 -
pinnacle 11 - sound capture problem
By lhg033 in forum Capturing and VCRReplies: 3Last Post: 1st May 2008, 19:56 -
sound problems with pinnacle 11
By lawzfeehily in forum Newbie / General discussionsReplies: 0Last Post: 10th Oct 2007, 10:58 -
Lost sound on Pinnacle Studio 10 on PC.
By Balliol in forum AudioReplies: 0Last Post: 17th Jul 2007, 18:25
