I am looking for a one click solution for my 82 year old father. The current method is to capture from cable using Windvr to mpeg2 using a Leadtek Deluxe card and then authoring and burning with TDA. The problem is that there are numeruos steps that he can't really remember. One problem is that Windvr saves the files with .mpeg extension and TDA only recognizes .mpg, so it is necessary to click on "all files" to see the file list. Also, there does not appear to be a way to get TDA to just burn automatically without several clicks. Ideally, I would like a solution with no more than 3-4 clicks from authoring to finished dvd. He doesn't need menus or editing. I don't want to buy any more SW either. I thought there might be some way to create batch files that would work with TDA, but haven't a clue how to create one that would work under this situation.
Any ideas would be appreciated.
Results 1 to 21 of 21
Get him a dvd recorder (tv to dvd), very simple setup and execution, and to boot, fairly cheap. Pioneer has some very good models. Start with dvr-220 and work your way up to prefeered model.
Quality is my policy. -
Is that what it was doing? How did you set it up? When I cliked on Burn under file, a screen comes up that shows a list of programs that I have already recorded. How do you get it to burn a scheduled program in the future? Thanks.
Sorry,My Mistake I always mix the 2 up.
http://www.intervideo.com/jsp/WinDVDRecorder_Profile.jsp -
Don't know what to tell you. Even the all in ones like Ulead Studio, require you to go through multiple steps. It is all tab/menu driven, and you don't have to log out of one software and into another. But you still have to follow the tabs and go through multiple steps. I've used it for some home video projects, and it works pretty good, and was easy to follow. Mine us Ulead Studio 7, but the current is Studio 9. It costs around $70.00, but if you buy it with an ADS Firewire card on ebay, you can get the card and the software for around $50.00.
Rob -
Ebay has Media Studio Pro 7 which supports up to dolby 5.1 sound with a buy now of $129.00. But I have never used it and can't speak for how easy it is or how many steps.. But it is a heck of a price for it.
Rob -
Thank you, but I don't even want to spend five dollars more than I already have. I am really looking for some sort of batch file solution or perhaps someone might know about some feature of the sw I already have that will solve my problem.
Thanks -
It is possible to do such things with batch files, if you use 'real' commandline tools (all the below mentioned programs are freeware). The following 'program chain' could be used for this purpose:
- Demux the mpeg2 with projectx or pvastrumento (CLI version)
(This will usually also clean up the mpeg2 for any transmission errors)
- Remultiplex with mplex (use - f 8 option)
- Author with dvdauthor
- Burn with nerocmd
All these steps can be started from a batch file. Another possibility is to set up some postprocessing in projectx to start up GUI for dvdauthor with correct commandline parameters (filenames). Then you could use the 'Auto accept video and audio files' option in GfD. Projectx would start GfD with the necessary parameters and the last remaining 'click' would be 'CreateDVD'
P.S. The only possibility to use TDA would be a macro tool like AutoItGUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
Autoit ( http://www.autoitscript.com/ ) worked a charm in combination with ulead videostudio. Autoit will be a big help in the futre; this program can do most anything.
Thanks -
Buy a DVD recorder.
What you want does not exist on the computer. At least not one that works well and doesn't end up looking like crap.Want my help? Ask here! (not via PM!)
Just wanted to update. Id did write a little scipt with autoit and was able to get the videostudio to start with the screen where you just pick the file to author. Then all I have to do is click next twice and output and burning starts. So I went from about 12 unclear clicks with TDA, to about 8 still unclear clicks with VS to 3 easy clicks using VS with autoit. He tried and was able to do it wihout much trouble. Thanks for pointing me to autoit.
Video CD/DVD Authoring Burning program Recommendation
By illyad in forum Newbie / General discussionsReplies: 3Last Post: 17th Feb 2012, 09:05 -
DVD Authoring Programs Disappear In The Midst of Burning Stage.
By mungbean34 in forum Authoring (DVD)Replies: 9Last Post: 13th Jul 2010, 02:21 -
Better to use non-upconverted files for authoring/burning to DVD?
By cognus in forum Video ConversionReplies: 4Last Post: 26th May 2010, 10:02 -
Need help by authoring/Burning AVCHD DVD (multiAVCHD/ imgBurn)
By benji179 in forum Newbie / General discussionsReplies: 0Last Post: 4th Apr 2010, 17:20 -
Automatic Gain Control in dvd-player?
By dynamique in forum DVD & Blu-ray PlayersReplies: 3Last Post: 29th Sep 2007, 10:34
