hi, I know there are lots of topics about this but I haven't found exactly what I need...
Here is the thing, I know that VCD, SVCD and KVCD files are playable with a DVD player, so Is there any way to add subtitles to this files for also be viewed on a dvd player, isn't possible to add the subtitles and then saving the file again.
thanx,![]()
FAR EASIER to upconvert from KVCD/VCD to DVD,
and add subtitles to the authored DVD project,
then what you are asking."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
If you go the way of SVCD, you could add OGM subtitles, which are switchable and aren't burned into the video. Guides are available here on how to incorporate them. However, most if not all of them are PC-based. Also, your player may not accept OGM subtitles, even if they're authored correctly. Some do, some don't.
You're better off getting a ~$50 DVD burner...
Scott -
basically what I said....
Urban Mac User
ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitles
By eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 09:22 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 18:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 10:23 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 17:28 -
Help with converting DVB subtitles to idx/vob subtitles
By Talayero in forum SubtitleReplies: 8Last Post: 21st Feb 2009, 18:10
