OK.
Once and for all, its time i get a grip on this.
If i'm watching a video and the sound and picture dont match, i can in some players adjust the relation (mplayer, vlc).
Does a positive value of X milliseconds make the sound move BEFORE or AFTER the picture? Its really frustrating when i'm trying to match this and i dont know what direction to go. None of the doc files i have seen have given good explanations.
Is there perhaps a good rhyme or memory rule i could use? 8)
Use "plus" to go forward in time. Use "minus" to go back in time.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
positive delay means that you delay the audio in relation to the video. (=you move the audio forward).
Just remember that it's called AUDIO delay, therefore it refers to the audio.Sorry, I had to go see about a girl -
You see a person clap their hands, and you hear the sound come in too late. You need a Negative Delay on the audio to correct this.
You see a person clap their hands, and you hear the sound before the visible action. You need a Positive Delay on the audio to correct this.
It is easy to get all screwed up on this, advise check several areas and actions. Also get a second pair of eyes and ears to verify. Lastly, make sure that your audio de-synch condition remains constant throughout the video, if it increases or decreases over time that a fixed delay amount will not solve your problem. -
thanks for your answers!
i will come back to this thread and use it as a guide the next time i have sync problems!
Positive or Negative Audio Delay?
By ropdoh in forum AudioReplies: 2Last Post: 11th May 2010, 04:37 -
Sound delay issue after MPEG2 editing (avidemux)
By dodoecchi in forum Video ConversionReplies: 8Last Post: 22nd Mar 2009, 05:55 -
can i rip DVD with pre-stated audio delay in ms (active or negative)
By deejay.2001 in forum DVD RippingReplies: 1Last Post: 29th Sep 2008, 04:09 -
question about how to delay or advance sound/audio on DVD
By jimdagys in forum Newbie / General discussionsReplies: 17Last Post: 10th Dec 2007, 00:08 -
sound delay
By hannss in forum AudioReplies: 1Last Post: 1st Aug 2007, 16:12
