Major/Anyone,
using ffmpegx build 0.0.9.t
encoding Mpeg-1 files to .mov so that toast can process to DVD.
Encoding seems to go ok, but when I go to play the files back in Quicktime,
I get the following error message:
"You may experiece problems with the video track
because of problems with the compressor.
Would you like to close the movie or continue?"
I choose continue, and the audio is great, but no video.
Same file in VLC 0.8.2 plays fine.
my system: OS 10.3.9, Quicktime 6.52 Pro, 2GB of Ram.
For some reason it seems to encode MPEG-4 with the 'DIVX' fourcc..? (But VLC reports the fourcc as 'mp4v'.)
You can change the fourcc to the regular 'mp4v' with MetaHoot, or install the DivX codec and it should play (though for some reason the file beachballs QT for me when DivX tries to play it).
Ok, I de-installed the DIVX 6 beta that I had,
and re-installed the DIVX 5.21 proper release from
the website. I am getting the "green screen" at the
front and bad lockups when scrolling through the file
in QT, as reported here below.
I will try running the file through DIVX Doctor II to see if
that corrects the file....."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
yes, not using QT 7...too dependent on QT 6.52.
3ivx is installed already ( notice my Divx Doctor II comment),
so I will test shortly...."Everyone has to learn, so that they can one day teach."
Urban Mac User
Divx Doctor II process the files, and gets rid of the
"green screen" at beginning, and makes the video file type
"generic mpeg-4"."Everyone has to learn, so that they can one day teach."
Urban Mac User
ASF to MOV or MPEG4 problems using FFMPEGX for Mac
By Maverick101 in forum ffmpegX general discussionReplies: 3Last Post: 29th Sep 2011, 12:54 -
Suggestions for MOV to MPEG4 and AVI converter
By ITemplate in forum Video ConversionReplies: 3Last Post: 29th Jun 2011, 13:36 -
[FFmpeg] Problems encoding a MOV
By Klagar in forum Video ConversionReplies: 0Last Post: 29th Apr 2011, 11:18 -
Encoding .DV problems with ffmpeg (e.g. MPEG4 -> DV or VOB -> DV)
By AlphaMonk in forum ffmpegX general discussionReplies: 1Last Post: 23rd Feb 2010, 04:24 -
Add chapters to MPEG4 MOV without reencoding
By Jonya in forum Newbie / General discussionsReplies: 2Last Post: 5th Feb 2010, 16:41
