I'm trialing the 'WMV to AVI MPEG DVD WMV Converter' V1.2.2 from Allok
Soft. But so far I have not been able to succeed with it.
I'm trying to convert a 3.9 MB WMV file. It's accessible here, for a
few days anyway (I'm at the limit of my free web space!):
http://www.terrypin.dial.pipex.com/Images/LED-Sequencer4MB.wmv
It's one of the first I've made with MS Windows Movie Maker 2.0.
(Content is irrelevant; it's for discussion in one of the specialist
electronics newsgroups.) The WMV plays fine in WMP, IrfanView, Nero
ShowTime, Real Player, and PowerDVD.
The reason I'm trying to convert it anyway is that one person in the
electronics group said the WMV wouldn't play in his WMP. No idea why
(surely that's the 'native' format for WMP?), but I thought I'd offer
him an AVI and MPG as well.
But after conversion to either AVI or MPG there are a variety of
errors.
For example, converting to MPG, I open the WMV, then:
For Output Format I select MPEG-II. I leave other settings at their
defaults.
After clicking Convert, I get a file led-sequencer4mb_tompeg2.mpg
If I play this (it's associated with WMP9 here) the 'spinning' text
effect is 'frozen'. If I choose MPEG-I instead, I get some of the
spinning back, but it's still not faithful to the original. Not sure
if the proportions are right either.
For AVI, leaving the settings at their defaults, it's much worse.
Using the defaults, the conversion plainly doesn't work because it's
too fast and the file is a mere 127 KB. Clicking it to play it in WMP
fails to run it, and I get I get a message about an unexpected error.
In Quicktime, nothing at all happens.
I repeated that with various different settings for the AVI. But
frankly I don't have a clue about choosing from those long lists of
codecs. So far I haven't found one, but I'm hoping that there is a
combination there that will work that someone here can suggest please?
BTW, is this program intended only for those who are deep into the
technicalities of video? Is there an alternative (ideally freeware!)
that a mere end-user can get results with?
Terry, West Sussex, UK
And you haven't taken this to their support people because ?
That would seem the logical course of action in a situation like this.
As for why it plays for you and not for him - he probably hasn't updated WMP is some time, and the early versions won't play the latest WMV files. You would be better off outputting DV-AVI out of WMM, then using virtualdub or similar to create an Xvid encoded avi. Smaller, good quality, and probably won't play in your friend's system because he won't have Xvid installed. But that is just life, really.Read my blog here.
If in doubt, Google it.
Thanks, will do.Originally Posted by jimmalenko
Still keen to solve the problem raised though.
gunslinger:
1) I had also emailed developer.
2) MovieMaker saves only WMV files.
Terry, West Sussex, UK -
Oops! I've looked a bit harder and I see I was totally wrong on point 2, sorry. I found that AVI (PAL) option under Other Settings.
However, it has converted my 4MB WMV to a 158MB AVI! As this is for web upload, that's out of the question.
Encode the AVI in your favorite MPG encoder? (You mentioned offering an MPG as a possibility in your first post.)Originally Posted by terrypin
I do the same with clips from the AVIs that I download from my MiniDV camera that I want to put on my web site for friends to view.
Just a thought,
Jim -
Thanks, Jim. Only into this scene for a few days so far, so can you/anyone recommend any such MPG editors please? Ideally freeware, as my usage will never be more than occasional!
I like TMPGEnc (enough that I bought TMPGEnc Plus 2.5), but there are others. Check the "Tools" link on the left-hand side.
Jim
Weird Problem - Adding subs to avi doesn't work okey on DVD Player
By andreas.cro in forum Newbie / General discussionsReplies: 6Last Post: 1st Aug 2012, 13:29 -
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 19:07 -
Converting Divx-AVI to MP4 - Output size option doesn't work
By tomzero in forum ffmpegX general discussionReplies: 6Last Post: 20th Mar 2010, 08:30 -
convert avi to dvd with ffmpeg doesn't work-why?
By lilly333 in forum ffmpegX general discussionReplies: 21Last Post: 18th Mar 2009, 17:00 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 06:58
