I'm having some problems with WMP10 and streaming video. When I'm a site such as cnn or fox and try to watch a video i click on it and there no video or loading of a video but can play a video in the player itself. Any ideas on this thanx all.
I reject your reality
and substitute my own.
- Adam Savage -
- Mythbusters - -
I was at CNN recently and it seemed that it wasn't loading properly but after waiting for few seconds it did. If I remeber correctly they don't use a progress bar which makes it appear as if there is no activity but the video is just buffering.
I'd assume that due to the huge amount of people visiting a site like that they may also be limiting the DL speed so it may take longer that usual to actually start playing. -
there are other sites other than cnn that use mp to display video that is not working is there a plug-in i may be missing
- Adam Savage -
- Mythbusters - -
No, the player is embedded in the HTML, to display you only need the player installed. If your blocking cookies that may be the problem, might be something else along those lines preventing the file from launching properly like a security setting.Originally Posted by dynamix1
<start plug>
Here's a link for a song that doesn't require anything but the player be installed, should download in few minutes, probably should start playing in no longer than 5 minutes at the very most if your on a 56k. Most likely it will start in a 2 minutes. It's 3mb.
http://www.40lbhead.com/headfiles/displayimage.php?pos=-780
Shoulders of Fate - 40lb Head
<end plug>
My ccokie seeting and security are normal. The link you directed me to doesnt work.
- Adam Savage -
- Mythbusters -
Trouble downloading streaming video/flash video from site
By imi in forum Video Streaming DownloadingReplies: 1Last Post: 23rd Mar 2012, 12:08 -
Video Card for Streaming Video from Laptop to TV via HDMI?
By serintin in forum DVB / IPTVReplies: 6Last Post: 4th May 2011, 18:12 -
Live video streaming on windows media server 2003.. video/audio is not syn.
By edirector in forum Video Streaming DownloadingReplies: 1Last Post: 15th Jul 2008, 19:05
