  1. New problem since updating to .9t
    I am starting from an .m2v and .ac3 file, taken from DVD streams (from either MacTheRipper or YadeX). Drop the .m2v in the source, select my desired codec, then go to the audio tab, Add Audio, select the .ac3 file, but the field remains empty, no error or anything, the audio is simply not added.
    Others have told me that they have had similar problems. I am trying to encode after manually typing the Unix path into the field, but I'm not hopeful.
  2. Thank you for reporting, I'll fix this bug immediately.
    Oct 2005
    Did this ever get resolved? I am using 0.0.9t-r4 and am still unable to add audio...
  4. It is scheduled for 0.0.9u to be released soon.
    Oct 2005
    Ahh! Many thanks...
