Hi, I am trying to capture with VirtualDub (I have a DC10+ card) after few seconds I got Win98 fatal error (Blue screen with some address direction), then I have to reboot my PC, with Studio DC10 plus software everything works fine, any suggestion on VirtualDub setting. Thanks.
I had this happen to me. Don't know if your problem is the same as mine, but I had to remove Virtual Dub from my registry and reinstall. I caused my problem messing with some cropping setting. I don't touch that anymore. I now crop after capturing.
Darryl -
You need to say a bit more information about your setup ie hardware /software and what codec are you using etc? if you are tying to capture in divx / and mp3 codec this oculd explain the blue screens. Most machines are not up to doing this and depends on graphics card proccesser drives and memory etc
VirtualDub for capture app?
By pgoelz in forum Capturing and VCRReplies: 17Last Post: 4th May 2010, 15:44 -
VirtualDub - Can't Capture Video
By rckowal in forum Newbie / General discussionsReplies: 0Last Post: 11th Jan 2010, 11:37 -
If VirtualDub capture, which one and what settings?
By tluxon in forum Capturing and VCRReplies: 3Last Post: 20th Jan 2009, 21:05 -
VirtualDub Filter During Capture?
By CosmicOutburst in forum Newbie / General discussionsReplies: 4Last Post: 26th Nov 2007, 19:48 -
Timestamping VirtualDub capture
By AIVAS in forum Newbie / General discussionsReplies: 1Last Post: 19th May 2007, 12:44
