I recently installed the new build (2.0.2070). I just realized that the buttons under the preview windows (see picture below from build 2.0.2034) are no longer there. Is there a reason they are not there or is this a problem?
Results 1 to 9 of 9
Sorry - I didn't see the "Player Buttons Missing" post from Sept. 4th.
After toggling between Menu and Movies - they reappeared. But if I click the "New Project" button, they disappear again. -
Can you try deleting any dnb_xxxx.xml files in the SVCD2DVD folder to see if that resolves the issue?
Basically the component for the buttons have been updated between these builds. I suspect a version issue here.
Can you post a pic of the latest build too?I recently installed the new build (2.0.2070). I just realized that the buttons under the preview windows (see picture below from build 2.0.2034)SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Playing with this a little I noticed the buttons are not always missing when the program is first launched. It is more of a random thing.
Here is a pic of the buttons when they do appear in build 2.0.2070 -
I had posted the same problem on September 04th.
It still exists.
Best regards,
Meise -
vicchiollo: Send me an email please i will send you a build to try to see if we can get to the bottom of this.
Where did my Google buttons go in IE
By DarrellS in forum ComputerReplies: 3Last Post: 9th Oct 2009, 18:36 -
More than 12 buttons with dvdauthor
By PeskyJ in forum Authoring (DVD)Replies: 7Last Post: 17th Dec 2008, 17:50 -
Menu with image buttons
By lex1972 in forum Authoring (DVD)Replies: 5Last Post: 24th Nov 2007, 08:02 -
Free buttons in GuiforDVDAuthor, how to...
By NormaJ in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2007, 11:05 -
Animated Buttons
By Paulodemoc in forum Authoring (DVD)Replies: 3Last Post: 27th May 2007, 16:39
