On eDonkey I downloaded a movie. I presumed I could double click it and it would play. The file name gives away that it is a DivX and AVI but nothing more. Media Player attempts to open it but states that it is an unknown format (extension .AVI).
Any ideas?
Thanks in advance.
Results 1 to 9 of 9
edonkey is very unreliable.
try opening the file with virtualdub, and then doing a direct stream (audio & video) output to avi.
Have you got a Divx-capable codec installed ?
https://www.videohelp.com/play#divx and https://www.videohelp.com/play#identify may assist you also.If in doubt, Google it. -
Thanks guys. I first tried Gspot.
It said "4CC: DX50/DIVX", name "DivX 5.0".
So I searched and download the DicX 6.0 here http://www.divx.com/divx/codec.php
And that worked. Many thanks.
But problem is that it turns out to be hardcore porn instead of normal movie that I intended. So that was my first and last use of eDonkey. -
I picked up two bits of SpyWare also
Uinstalling eDonkey now. I thought things has changed since KaZaA, but it appears not. -
Be careful what you discuss here. You clearly downloaded what you throught to be a Movie. Most likely something that had not been officially released yet right?I picked up two bits of SpyWare also sad.gif
So in a nutshell, it was WAREZ and if that was the case please choose your words carefully. Please read the Rules before posting specially to new members. I don;t want to have this resource shut down by Big Brother over some well meaning statement by a poster.No DVD can withstand the power of DVDShrink along with AnyDVD! -
No warez, just home brewed content
There are lots of people producing their own films and using P2P to distribute them, as a way of gaining recognition.
Besides my posts say that P2P appears crap.
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 08:28 -
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
What does Windows Media Player use to play DV AVI files?
By CursedLemon in forum Newbie / General discussionsReplies: 5Last Post: 19th Nov 2009, 01:12 -
How to play H.264 avi in Windows Media Player?
By TheMoreYouKnow in forum Newbie / General discussionsReplies: 2Last Post: 21st Sep 2009, 03:47 -
Media Player Classic can no play DivX files
By siluet in forum Software PlayingReplies: 6Last Post: 30th Sep 2008, 16:46
