I've had various issues with Media Player 10 in the past. One of which is an error when trying to play a DVD - and then it won't play. This recently happend (I just re-installed Windows, so fortunately I know what did it) when updating Nero. I rolled back before the update and I'm good again. Is there some issue bet. wmp 10 and Nero? I don't have it set as the mpeg2 player either in WMP 10.
Originally Posted by Krispy Kritter
I wish there were a log of the error somewhere.... -
Have you tried looking the event viewer...its a long shot, but windows might be seeing some issue.
And, unless I'm mistaken, Nero has a media player. So it could be installing its own codec or corrupting the WinDVD codec. By installing WinDVD after Nero, the WInDVD codec shouldn't have any issues.
You can also check which codecs are installed and/or being used by your system.Google is your Friend
H264 Playback Problems in WMP 11
By seasonsofwither in forum Software PlayingReplies: 3Last Post: 21st Dec 2009, 22:49 -
Vista Enterprise problems with WMP 11
By jyeh74 in forum Newbie / General discussionsReplies: 11Last Post: 22nd Mar 2008, 19:18 -
WMP 11 problems?
By rmunk in forum Software PlayingReplies: 2Last Post: 10th Dec 2007, 14:50 -
WMP
By marlo in forum AudioReplies: 0Last Post: 23rd Nov 2007, 15:50 -
Audio Sync problems with MKV file using WMP
By jradams76 in forum Software PlayingReplies: 0Last Post: 23rd Jul 2007, 11:51
