It takes me about 4 hours to convert a normal avi to dvd via this prog and this is the only 1 I can get too work.
Can anyone help me find out why this is taking so long?
I have win xp sp2 on an xp3200+ with 512mb ddr 400 memory and 120g & 200gb h/ds with plenty space left.
Please help because I keep reading of folk doing this very quickly and don't undestand what I am doing wrong?
Could this be codec related?I am using the Kazaa lite codecs...
Thanks very much for any help![]()
Results 1 to 18 of 18
It takes me one hour to get to work and my friend can get to work in 20 minutes. Can you tell me why?
Quality.Originally Posted by Nelson37
It certainly shouldn't take that long. Have you tried other avi's - the one you have may be "Unusual". Maybe a defrag could help.It takes me about 4 hours to convert a normal avi to dvdSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
You're a funny bloke
Seems a reasonable question if the general consensus take 40-50 mins and it takes 4-5 hours on mine (esp. as other software doesn't work) that I wonder why.
Thanks for the reply Chrissyboy.
No this is the normal story with all avis I've used (all diff codecs etc.).
This is a completely new h/d... -
Well it depends on the duration of the avi. I would say real-time encoding should be achievable at least for you. i.e. a 2 hour avi should take no more that 2 hours and a 1 hour avi should take no more that 1 hour.
If you are not getting close to this then (assuming your disks are not hopelessly fragmented), you may have a rouge avi file… is this consistent over several avi files you have tried?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Yeah every one for the last couple of years (and had a few lol!)
Thats why I was wondering if it was either the codecs or maybe a memory problem, becuase the pc is fine with all other software... -
AVI support is a recent thing...
Can you post/email me a log of such a run so i can take a look?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
FYI, codecs are not an issue with SVCD2DVD - it doesn't use any!
Aye sorry Chrissyboy I mean using other progs and converting from avi to other formats.
Really nice bit of software btw
Not meaning to sound stupid but how do I find/create the log you want m8?Going to do one just now so will mail it in the morning
Thanks for the amazing support btw -
Thanks!
Logs are in "C:\Program Files\BadgerIT\SVCD2DVD v2\logs" by default but may vary depending where you installed the software.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Guess it wasn't obvious enough.
In order to make time calculations, length of AVI, type of AVI, resolution of AVI, and bitrate selected, among other things, would be needed for comparison.
You need to give more information. That was the point of my earlier post.
Also, the Kazaa lite codec pack has been a source of extreme problems for many people. If a program is re-encoding an AVI, that AVI is being decoded by a codec of some sort, unless of course it is uncompressed. The codecs included in that codec pack often cause issues such as you are experiencing, among numerous other problems. -
I was just giving a generalisation Nelson.thanks for the info.
I am now managing to convert and burn in about 2 1/2 hours (burning at 4x).
Example is a PAL avi 1h 37min and 37 secs in duration and 698mb in size.It is 512x288.
All settings are default and I am in a PAL area so do not need to re-encode.
So is this a reasonable time compared to others?
I need to point out that I am over the moon with this prog as no other one works and this nearly always does.
Excellent work CB
It’s not too bad. HD spec is important here....
I would say that we would need to know more about your setup to comment further:
- HD speed (5400, 7200 or more!), cache size
- What’s your fragmentation/fragmentation strategy?
In general that time is not bad but I have a slower computer than you and I get real time if not better!
I have 2.8 CPU but I defrag every night and have a 7200rpm 8MB cache HD….SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Mmm your drive should be white hot!
Can you email me the log of such a run.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Chris I attached it to the post, but can't seem to see it, could you pm me your email addy plz?
Thanks again
Its on my profile.
Taking out the second audio?
By raitono in forum EditingReplies: 22Last Post: 25th Jan 2011, 13:12 -
taking image from bluray
By pcb in forum Authoring (Blu-ray)Replies: 1Last Post: 15th Oct 2010, 04:17 -
881017 - taking stills
By hamidi2 in forum Newbie / General discussionsReplies: 0Last Post: 7th Jan 2010, 08:26 -
Medieval helpdesk. What tech support was like in the middle ages.
By freebird73717 in forum Off topicReplies: 2Last Post: 4th Jul 2009, 23:05 -
SVCD2DVD taking AGES to convert files.
By smileymyley in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 22nd Jun 2007, 14:53
