    May 2001
    PokeMP3
    I used to do this all the time, open up the DVD2AVI file in TMPGEnc, without any problems at all, but since i reinstalled all the stuff on my computer: No Go!
    anyone got a clue? please tell me
    NdZ
  2. Did you install the VFAPI codec from http://www.tmpgenc.com Also check Options | Environmental Settings, and then the VFAPI tab and make sure DVD2AVI is checked and/or raise its priority.
  3. You aren't saving as AVI are you? Save the entire project instead.
    Darryl
    May 2001
    PokeMP3
    saving as a project
    And i found the error; DVD2AVI version 1.76, plugin 1.74
    where can i get the newer version. any idea?
