Hi,I need really help.I edited 61minutes of my DV AVI footage in Premiere and then used Mainconcept to encode it.I shows some artifacts and picture isn't so clear.I was expecting better picture as I used 3CCD camcorder.
Anyway later I tried to save project in Premiere as AVI and then imported to
Adobe Encore.I heard Encore is good in encoding because it calculates everything for you and doesn't waste a space.But picture wasn't so good.
Please can someone tell me how to encode it??Should I use VBR 2 pass or CBR.Footage is mainly from my vacation.And what encoder to use.
Thank you so much
There are a couple of things that you didn't mention in your post. What audio bitrate are you using? When you say Mainconcept, does that mean that you are using the Adobe Media Encoder? I would recommend using the Adobe Media Encoder straight out of Premiere rather than rendering to AVI and using Encore. From what I understand, Premiere and Encore use the same exact MPEG-2 encoder from Mainconcept. I would also recommend using the Videohelp bitrate calculator at https://www.videohelp.com/calc.htm . Plug in the length of your program and the audio bitrate and the calculator will tell you what average bitrate to use in Mainconcept. For your maximum bitrate assuming that you are recording to DVD-R, choose 7 Mbps. Your video sounds like it is short enough that you can use CBR. Also, don't expect that the DVD will look as good as the video out of camera. I have a Sony VX2000 3-CCD camera and my DVDs never look as good as the original. At the very least they have lost two-thirds of their information by going from DV25's 25 Mbps to the typical DVD's 7 Mbps.
Tools used: ScenalyzerLive 4.0, Adobe Premiere Pro 2.0, Adobe After Effects 7.0 Professional, Adobe Encore DVD 2.0, IFOedit 0.96, DVD-lab PRO 1.53, Adobe Audition 2.0
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 14:46 -
ENC encoding versus no ENC encoding
By RL in forum ffmpegX general discussionReplies: 3Last Post: 4th Feb 2011, 17:44 -
AVCHD encoding format vs. H.264 encoding format?
By coody in forum Authoring (Blu-ray)Replies: 3Last Post: 28th Aug 2010, 20:51 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 14:11 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 00:31
