    Sep 2005
    Lithuania
    Hi, im kinda new in this converting world
    So, i have a problem. I need to convert rm video to XviD (that could my standalone dvd player read it) and resize that video from 4:3 to 16:9 (not to cut the edges, but resize). Is there a tool, that could do that 'actions' at the same moment or should i convert to avi and then resize it?
    Thx in advance...
    Dec 2004
    Australia
    mencoder can do it or you could frameserve via AVISynth using directshowsource.
    Sep 2005
    Lithuania
    Thx for fast reply... Im trying frameserving with that tool, u suggested... Anyway, i loaded video file, video plays, but no sound... I guess this tool doesnt 'understand' real media audio. Can somebody tell me how to fix this?
    Dec 2004
    Australia
    Does it play via dshow with audio? What audio format anyway? Cook? AC3? aac?
    You could try mplayer to decode to wav, then use wavsource() and audiodub().
    Sep 2005
    Lithuania
    Audio format: Real Media audio (rma)
    As i said that frameserving tool dont support rma... Anyway, i think that i need the easiest way. I tried eo-video (name could be different, my memory is poor). Its real simple, but... ...not free :/
    I think ill try mplayer
