If I have a Divx or XVID AVI file that has a bitrate of 1200 or so and I am converting it to MPG2 for DVD, is there a benefit to converting the bitrate to 4000?
MPEG is not as efficient as Xvid -- it will require 2 to 4 times the bitrate to keep the same quality. Just use the constant quality mode in your MPEG encoder. Pick the quality you want and encode. That way you'll get exactly the "right" bitrate for your MPEG file.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
how can I reduce bitrate and frame rate when converting avi to mpeg-2(dvd)?
By jasoothai in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2011, 04:42 -
Any way to set default DivX bitrate in AutoGK ?
By spidey in forum Video ConversionReplies: 2Last Post: 17th Jul 2008, 02:11 -
Divx 6.8: bitrate vs target quantizer?
By peggypwr1 in forum Video ConversionReplies: 1Last Post: 5th Feb 2008, 22:35 -
recommended bitrate for dvd to avi
By blarson in forum DVD RippingReplies: 4Last Post: 10th Jan 2008, 12:17
