Well, after trying for so many times using the tutorials in this site and failed several times, I figure I will just ask the questions. Don't worry, I used Search. :P
Anyway, the first question: I got a Japanese movie, subbed with Chinese sub (BIG 5, I believe) and in MKV. Using Virtual Dub, I was able to separate them into two parts, audio/video and the .srt file. Now, I need a program to join these two with the subtitles actually showing and the quality kept. Well, after trying all the programs in the tutorials, none of them work. The biggest problem I am having is that I can't view the CH subs; I can view them just fine when I open the .srt file with Notepad, but when I try to attach it with a program like AVI2DVD, the preview shows a bunch of codes I have no idea what are they. The same goes for WMP and VLC player. When I try to watch the original MKV file in VLC player, it shows blocks. How do I fix this?
Depends what format you hard sub to. If you re-compress to a lossy format (MPEG2, XviD, etc.) then you are going to loose quality.
It doesn't matter what format I am going to convert it to, as long as I can make a DVD with it without any loss of quality.
Well that is the point. You can't. DVD is MPEG-2 and MPEG2 is lossy.
For a DVD I would recommend authoring with seperate subs. If you check the guides there should be some on authoring a DVD with subs.
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 16:50 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 18:30 -
Questions about few things. DVD to Divx with permanent subtitles, etc
By Earthling2000 in forum Newbie / General discussionsReplies: 6Last Post: 9th Jan 2009, 14:15 -
Add subtitles to dvd menu - core questions
By Arcanis01 in forum Newbie / General discussionsReplies: 3Last Post: 26th Nov 2008, 16:46 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 19:08
