With the introduction of improved-spec and cheaper DVD recorders, is there any point in keeping my ADVC-100? IOW, would I see an improvement in the quality of footage recorded from a VHS VCR to a DVD recorder?
Many thanks.
I seriously doubt there is a way to increase the quality coming from VHS to DVD. VHS is usually terrible quality video no matter how good your equipment is you can not come up with a copy that is better than the original without some SERIOUS work.
The real answer lies in completely understanding the question! -
It really depends on whether you edit/cut/trim/add transitions/add menus before burning to DVD. If you do nothing but transfer the VHS then the stand alone DVD recorder is the way to go. But if you do the stuff mentioned above then it is better to do it while the file is DV avi.
You can still do the stuff mentioned above using a DVD recorder BUT you will be dealing with *.vob --> then mpeg and that can be more troublesome to work with. Frequently you end up with audio sync issues. If you are really knowlegable and have the right software then you should be able to use the stand alone DVD recorder.
Personally, I would hang onto the ADVC-100, you never know when you may need it. I am not saying do not get the DVD recorder but also hang onto the Canopus.bits -
Thanks m8
Yes, I would usually do this.It really depends on whether you edit/cut/trim/add transitions/add menus before burning to DVD
It sounds from what you say that a DVD recorder would compress whatever I would record into it from VHS, just as an ADVC-100 would (though the type of compression may be different). I would then import the footage into my NLE, edit it, then author it.
Six-of-one or half-a-dozen of the other? Whether there's any gain quality-wise might be debatable...
Cheers wwjd. -
You can regain some of the quality on machines using LSI chipsets (JVC, for example). The filters remove grain and chroma noise, something your current device cannot do. Get one, you'll love it.
But that said, I'd not toss out the Canopus. If you want AVI, it'll still be handy.Want my help? Ask here! (not via PM!)
How you can use a stand alone DVD recorder and your Canopus 110
By fuzzblaster in forum Capturing and VCRReplies: 22Last Post: 3rd Oct 2010, 13:06 -
ADVC 100 and ADVC 300 non recognized in Windows
By scardi in forum Capturing and VCRReplies: 4Last Post: 28th Feb 2010, 02:23 -
Typical lifespan for a stand-alone DVD recorder.
By usually_quiet in forum DVD & Blu-ray RecordersReplies: 114Last Post: 27th Nov 2008, 22:21 -
Looking for a Stand alone, cheap, DVD recorder, timecode on screen.
By AtomX in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Feb 2008, 17:10 -
ADVC-300 vs. ADVC-100
By DeadLily in forum Capturing and VCRReplies: 11Last Post: 19th Sep 2007, 09:15
