well im pretty sure this might have been asked but i have 2 problems i think...
Well ill start with what im trying to do; I want to do either 1 of 2 things. One being adding perm subs to an avi file, I have the movie.avi and .sub, with the addition of the .srt subs i converted with the sub maker.
I know you use Virtual Dub mod or other to do this but whenever i try to load the mov i get the, You dont have the right codec... windows media.... blah blah error. My first question is what must i do for this to work, or what am i doing wrong?
The other thing i might want to do if it is necessary,( i really wounldnt preferr this) it would be making a Avi w/ subs to DVD, now i have read much if not all of the tutorials about doing this but it seems like i get some kind of error or another while on some of the last steps.
oh and i have no problem watching to mov with the subs, but for some reason it only works on Windows Media 9 and up. but that isnt a problem for me
Please help me out^^
Install a codec that handles whatever fourCC the error says. So if it is complaining about no decoder for XVID, install XviD.
could you give a link to a place to get the right codec?
cause i do believe i have most, but it still doesnt work>.<
or better yet, another program to add the .sub or .srt to the .avi -
No I can't, but that is your fault not mine.
You are going to have to do better than blah, blah... You need to tell us the fourCC.
You could have all codecs bar one and if the file happened to use it then the fact that you have all the others really doesn't help.
Any app that relies on VfW won't work either.
You may also be able to get away without installing anything by enabling ffdshow to handle the fourCC (via VfW, not dshow) since ffdshow can decode most commonly found stuff. -
Nm i found out that it was a problem with the encoding of the .avi...
sorry>.<
Adding subs to avi format?
By Avon in forum SubtitleReplies: 2Last Post: 14th Aug 2011, 13:20 -
Adding subs to a .avi file
By stgdlf in forum Newbie / General discussionsReplies: 7Last Post: 21st Nov 2009, 01:34 -
Adding Subs to Avi
By ill_kuma in forum SubtitleReplies: 7Last Post: 9th Feb 2009, 21:02 -
having trouble adding permanent subs wtih vdubmod
By myname77 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Nov 2008, 10:08 -
Trouble adding permanent subtitle to xvid, subs don't break right
By boblydan in forum SubtitleReplies: 8Last Post: 18th Jul 2008, 20:53
