Okay I have Pearl Harbour 20th Aniversary edition which i would like to backup to a dvd5. Its a two disc dvd9.
Anyways prior to putting it through CCE i would like to remove a few parts with DVDRemake one being the option to bypass the parent control etc.
Now if i hide this block with dvdremake will the dvd still be functional? I know i can use pgc edit to bypass it but i want to remove it to gain as much space as possible from the dvd so that i can result in a very nice bitrate.
yes but so does dvdremake which is what im using IMO alot easier than vob blanker as it has a nice preview... but my question is will it remove the functionality of the dvd if i was to remove it?
Use DVD Shrink in reauthor mode and drag just the main movie across. Kill off any audio you don't need. Now you have maximum bitrate for the movie. Save this out to the HDD with the compression settings set to no compression and all you will be doing is writing the new disk structure - Shrink won't touch the video. Now you can use CCE (I assume through DVD RB) to re-encode your disk.
Read my blog here.
They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin
How to remove the language selection menu from BR Disc
By The-One in forum Authoring (Blu-ray)Replies: 21Last Post: 27th Apr 2014, 17:00 -
Parental control for mac
By EmmaL in forum MacReplies: 5Last Post: 12th Aug 2010, 21:09 -
Parental Control
By HotDamn! in forum ComputerReplies: 13Last Post: 22nd Feb 2010, 21:50 -
WMP11 Parental Control
By jonghyunchung in forum Software PlayingReplies: 2Last Post: 4th Jun 2009, 14:55 -
help: parental control MARK tfe200
By moagutn in forum Newbie / General discussionsReplies: 1Last Post: 28th Jun 2007, 02:45
