can anyone copy them yet
does anyone no what size mem card u need to get a full movie on to play on the psp thanks
Results 1 to 18 of 18
thanks for your help
Moved to Off Topic.
just my thoughts here......I would think that would depend on the bitrate of the movie? I would also think I would just buy the biggest card I could find just in case.
If at first you don't succeed; call it version 1.0 -
I can get 2 on a 1 gig stick but I haven't looked into it properly.Originally Posted by louise2005
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
out of curiousity does anybody know the proper format/specs to use?
mp4 the movies have to be i found load of movies and psp games on the yet thanks for your help
thanks for your help -
Can anyone understand what this person posted?Originally Posted by louise2005
If I may. Ahem.Originally Posted by smearbrick1
"I'm a warez monkey and I have no qualms about not reading the FAQ and posting the results of my quest for dubious software and movies here for all to see."
I'm fairly sure thats the gist of it.
i said i found loads of movies for the psp there where mp4 format do u still need me to translat it for u smearbrick1
does anyone no where to find a downgrade for the psp from v2.01
just go online with your psp and use the update feature built in ...
since it has wireless built in - finding an access point is not hard .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
oh - i re-read that ...
there is no downgrade i believe ....
2.01 added more security features ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
don't worry about it louise2005 as smearbrick meant nothing by it
. It was a little hard to comprehend and questionable so some people like to point out grammar/spelling etc. Seeing as there's nothing much else to do round these parts apart from play silly thread games let them get on with it. If that's what they get their kick out off then wahoo for them
(shame on you Flaystus though
:P
I see you are from Boro though I don't know if you are a football fan but anyway, areet 8)
:cough 2-0 :P:
I was just gonna point that outOriginally Posted by BJ_M
Just as MackemX pointed out, I'm very bored and very easily amused.
nice name mackem x yes iam from boro whats wrong with that
lolthanks for your help
I thought UMD movies for the PSP were dead?
By yoda313 in forum Off topicReplies: 0Last Post: 6th May 2010, 10:58 -
PSP Test Clip: Need someone with a PSP to test for me!
By FulciLives in forum Portable VideoReplies: 5Last Post: 17th Feb 2009, 20:42 -
My XviD4PSP PSP video conversions are not supported on PSP
By godfist314 in forum Portable VideoReplies: 3Last Post: 18th Aug 2008, 10:59 -
Downgrade your PSP to version 1.5 using your PSP battery
By chrise in forum Newbie / General discussionsReplies: 1Last Post: 20th Dec 2007, 08:27 -
Nero 8 Recode to PSP - No Title on PSP?
By sonicm in forum Video ConversionReplies: 1Last Post: 6th Dec 2007, 14:13
