Hi,
I'm trying to convert an avi (encoded with h264 codec) to xvid with virtualdubmod. But everytime after a few % done I get an error (see picture).
I can play the files but I can't convert them. And I've tried using different versions of VDM and even virtualdub but always the same problem. I even tried using alternative convertors but it didn't work also.
I've read somewhere that it might have to do with the h264 codec.
Does anyone know a way to convert them to xvid or divx5?
thanx a lot!
check https://www.videohelp.com/forum/viewtopic.php?t=279355
and try latest ffdshow as x264/h264 deocder or if it wont work try some older ones. -
Thank I've already read that thread. I've used the latest ffdshow and virtualdubmod still crashes. I guess I have to go looking around for some others
I had many problems when working with my first x.264 avi file, too, but at the end I could make it work. What I did was:
- Uninstalled any previous version of ffdshow
- Cleaned the Registry of Windows
- Installed the latest version of ffdshow
- Enabled its x.264 decoding to VFW
Also I guess that if you have any codec pack installed, it may be messing up your VD. -
I have uninstalled every videocodec, cleaned registry and installed ffdshow, but virtualdub still crashes
. I have even tried different versions of ffdshow beside the 20050909 and the latest one.
why
doesn't it work?
Problems converting some xvid to h264 to append to another h264
By PlanetIndigo in forum Video ConversionReplies: 3Last Post: 6th Jun 2011, 14:13 -
How do I get best settings for XviD using VirtualDubMod?
By helloworld123 in forum DVD RippingReplies: 4Last Post: 17th Aug 2010, 19:14 -
Simple CROP of AVI (XVID) in virtualdubmod
By Rudyard in forum EditingReplies: 4Last Post: 1st Jun 2010, 20:43 -
H264 MKV files on VirtualDubMod
By raylgo in forum Video ConversionReplies: 5Last Post: 22nd Feb 2009, 10:25 -
MPEG2 to Xvid with Virtualdubmod
By Cazz in forum EditingReplies: 25Last Post: 26th Feb 2008, 13:49
