Hi, folks.
I'm looking for a DVD recorder that is as simple to use for recording as a VCR, where you just press Record to start and Stop to finish...no need to finalize, etc. One of the main reasons I want to keep it simple is that the recorder will be in a common area where it will be used by a number of different people.
I don't need menus or editing or anything else besides straight recording from an analog video camera. I'd consider using +/-RW discs instead of just +/-R if that makes the recording process easier. The recorder would be used for about 150-200 one-hour recordings per year.
Any suggestions?
Anyone of them will do that. You do have to finalize after you have filled the disk or it will not play back on another machine.
No DVD can withstand the power of DVDShrink along with AnyDVD! -
Originally Posted by jtoolman2000
Wamart has the Pioneer-220-s for
$198.76, does everything you asked.
http://www.walmart.com/catalog/product.gsp?product_id=2598467Quality is my policy.
Most reliable BD-R media?
By Sephiroth666 in forum DVD & Blu-ray WritersReplies: 14Last Post: 26th Apr 2012, 08:24 -
Is this a reliable retailer ?
By Zetti in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 12th Dec 2009, 21:29 -
Can Anyone suggest some REALLY REALLY basic easy editing software
By Jan29 in forum Newbie / General discussionsReplies: 7Last Post: 20th Jan 2008, 21:04 -
Reliable +R DL media?
By Sephiroth666 in forum MediaReplies: 16Last Post: 4th Jan 2008, 03:42 -
Is DVD-RW backup reliable?
By bevills1 in forum ComputerReplies: 15Last Post: 21st Jun 2007, 15:01
