when i use this program to make chapters all is fine until I go to click on output and say begin output. then instead of working it closes down program but i noticed it had made volume 1 folder but didnt put chapters on just empty folder
Are you sure you are not using a "modified" version of that program??Originally Posted by natty
The folder would be there because the program 'attempted' to author but closed down; this would also explain why the folder is also empty. This program is very easy to work through and ideal for beginners upward.
I suggest you just go through it slowly and logically and i'm sure you'll get it right. I have entered the following steps pretty much as an absolute idiot/muppets guide to this; you just CANNOT get it wrong; if you do, then i give up!!
1. click create new project;
2. click add file;
3. now browse for where your mpeg2 file is and press 'open';
4. now click 'chapter cut edit' at top of screen;
5. now click the 'add' button just above 'OK';
6. i always use 'automatically insert a specified no. of chapters at a fixed interval'; this is a preference thing here; but you could click here and then enter the no. of chapters you wish to insert; then press 'OK';
7. now click 'OK'
8. now click on 'create menu' at top of screen;
9. again this is a preference thing here-do you have a menu or not; if so, what type of menu etc etc. Just try WITHOUT a menu for now; On the drop down box to the left select 'No Menu'. This wording will NOT appear on DVD-just ignore it;
10. now click on 'Output' at top of screen;
11. Ensure 'Create DVD folder' is ticked; now browse for where you want to put the created VIDEO_TS and AUDIO_TS folders; click 'Begin Output'.
12. JOB DONE!!!! You can then open up the incorporated burner and then burn to disc (make sure file size is appropriate for disc size). -
did exactally as u said thegeeman but when i click on output program closes down just cant understand this as i have used this before np. is there another program which can make chapters for me on movies
is there anything dvd author needs or maybe i am missing as i have used this before no problem never closed down before it had authored movie like its doing now I am using version 1.6.26.73
Maybe try
1. an uninstall;
2. delete folder from 'My Computer', 'Program Files', 'Pegasys' etc,
3. then reboot;
4. re-install, then a final reboot. -
well at long and very frustating last I have sorted my problem it was a .dll file called sfmpgdec which was corrupted even after i reinstalled it now I got a better dll and it works fine thanks all for helping
