Hi, what do people here know about DVD Audio and how do you burn it? Can I do it with iDVD?
Not that I'm aware, and I do not think you can make
it with DVD Studio Pro."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
You need to use dvda-author. The bloke who codes xACT has made a GUI but I'm afraid I can't find the URL. If you need it you can try contacting him via the xACT Yahoo group.
Toast 7 will make audio DVDs, but I suspect it's only from AIFF files, The DVD audio spec allows for a much more robust sound format, but I'm not sure what you'd use to create it (assuming you're creating your own music or making live recordingsa; if you start out with a CD as your source, then Toast is fine)
Toast7 makes what they refer to as "Music DVDs", which are standard DVD-Video spec discs, with the bitrate emphasis on the audio, using some still picture for the video. It is focused on creating discs with compressed audio (AC3 or MP2--mp2 more likely), so one can load up long playing times/numerous tracks on a single disc.
Not to be confused with the DVD-Audio spec (which Toast doesn't support yet).
Scott -
Supports any audio file as the source - output is dolby or pcm, up to 96khz/24-bit pcm.
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 05:27 -
audio problems when burning a DVD
By cosypete in forum Authoring (DVD)Replies: 3Last Post: 9th May 2010, 18:23 -
Burning DVD audio problem
By Jragon16 in forum Newbie / General discussionsReplies: 4Last Post: 7th May 2009, 22:20 -
Audio messed up when burning .mpeg on DVD +R
By greenda4 in forum AudioReplies: 16Last Post: 19th Nov 2008, 15:52 -
Audio syncing when burning DVD's
By thatoneguy99 in forum Authoring (DVD)Replies: 2Last Post: 21st Jun 2007, 02:43
