I'm trying to use TMPGENC to cut an MPEG2 video, which has been converted to PAL from AVI. I specify the start and end frames in the edit window, but the resulting MPEG starts and ends about 6 seconds earlier that I requested. Why is this? Am I doing something wrong in TMPGENC?
Apologies for replying to my own post.
I guess the answer is that MPEG files should not be edited except by a professional editing package. TMPGENC will only edit up to the GOP border, which means that there could be any number of pictures either side of my edit frame that form part of the same GOP.
It surprises me, however, that there could be so many frames (6 seconds worth) making up a GOP. Is this reasonable in a normal MPEG?
Moral: Make changes in the raw AVI first.... -
Maybe this is the simpleton in me but why not just edit when you author?
Are there any software that will SIMPLY cut and merge *.mts without re-enco
By skydutch in forum EditingReplies: 1Last Post: 12th Nov 2011, 04:04 -
How to Cut & Merge mini 10 part mini series?
By skorpinok in forum EditingReplies: 5Last Post: 8th Oct 2011, 09:41 -
Cut and Merge MPEG-2 Files
By flash_49 in forum EditingReplies: 8Last Post: 12th Feb 2010, 10:03 -
How the cut and merge function works on your dvd recorder?
By v1p0n3 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 5th Jan 2010, 05:59 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02
