Bought my friend a Hp lightscribe dvd burner as a xmas gift, he bought a laptop and decided to get rid of his home pc, so he bought a external case that would allow him to use his internal HP dvd burner w/ the the laptop, the only problem is the drivers that came w/ the drive are only for the internal model, and HP wants him to pay them $10 for them to send him a copy of the external drivers. I have went to drverguide.com and checked two dvd firmware pages, can someone direct me to a site that has them online, or email a copy, I have a easynews account if you wanted to forward them their, that would work as well. Thanks !!
Michael![]()
If I'm not mistaken the drivers you would need would come from the external case not from HP. What is the brand of that external case? Not all external cases will be compatible with internal dvd burners. For instance for BENQ 1620 drives using a external case with the PROLIFIC chipset that works well. I've read the PLUMAX enclosures use the PROLIFIC chipsets.
I'm pretty sure the drivers he needs will come from Hp, because the internal drivers don't recognize usb as a option only master slave and cable. So even though he has the 640 software installed the software can't detect the drive.
Pioneer DVR-640 HS - can it record in PAL?
By Spiny Norman in forum DVD & Blu-ray RecordersReplies: 6Last Post: 24th Aug 2010, 16:16 -
how to record with 640*352 format
By Haboob1st in forum DVB / IPTVReplies: 5Last Post: 3rd Jun 2010, 18:39 -
640 ac-3 for DVD
By chrchr in forum AudioReplies: 57Last Post: 12th Mar 2010, 13:16 -
Authoring a DVD with AC3 640 bitrate - can it be done?
By Slimbo69 in forum Authoring (DVD)Replies: 11Last Post: 9th May 2008, 09:11 -
Would 640 X 272 to 720 X 400 be correct?
By hydrophonicaudio in forum MacReplies: 19Last Post: 24th Jul 2007, 10:33
